17 Diesel additives and their ratings--pdf
Old Jan 2, 2021 | 06:40 PM
ForBruce's Avatar
ForBruce
The following was taken from "The Diesel Place"
I decided on opti-lube summer----(4th in the list)
any one know any coupon codes for their web site. ( the web site with the cost of shipping seems to be the lowest)
1/3 sunday NOTE.......bought diesel at BJ's trip down to Georgia about 200 miles ...got about 10 miles per gallon towing a 16,000 lb 5th wheel
but on the trip back bought from "TA-Truck Stop" and got 13.2 miles per gallon....
Conclusion.....IMHO...what ever the Cetane rating is or the additives used..i believe a difference can be made by adding to the fuel
File Type: pdf
Old Jan 2, 2021 | 07:28 PM
Thamac15's Avatar
Thamac15
I’ve used Opti-lube Summer+ since 1k miles on my 17 with their Winter blend in the winter. Just hit 50k miles today. Does it work? Who knows!
I order them from Amazon, prime shipping.
Old Jan 2, 2021 | 07:47 PM
Painted Horse's Avatar
Painted Horse
I use the Opti_lube Summer most of the year and XPD during the cold months.
The problem with that Diesel Place rating. It was done in 2007 and who knows what additives have undergone improvements
Old Jan 2, 2021 | 08:07 PM
Pugga's Avatar
Pugga
I’m in uncharted territory, i’m running hot shots EDT in the summer and their anti-gel stuff in the winter.
Old Jan 3, 2021 | 11:58 PM
JGORD's Avatar
JGORD
I fill up at Kum & Go in CO. Their diesel is treated with Power Service for summer and winter, or so the pump says.
Old Jan 4, 2021 | 03:07 AM
Killer-Bimmer's Avatar
Killer-Bimmer
I seem to be an outlier as well as I’m using Red Line 85+
https://www.redlineoil.com/85-plus
Always had good results with other Red Line products and this seem to be decent... haven’t seen much mention of it though🤷‍♂️
Old Jan 4, 2021 | 05:23 AM
BillyE's Avatar
BillyE
It’s rather expensive compared to the others.
Old Jan 4, 2021 | 05:58 AM
Killer-Bimmer
it’s same price point as Opti-Lube in the 1 gallon version. I’m running 8oz of it per 45gallon fill-ups so about $4.69 additional per fill. I could run even less down to about $1/fill, but picked a mid point of supposed benefits...
Old Jan 4, 2021 | 10:42 AM
BillyE's Avatar
BillyE
I haven’t seen it at that price. Where are you getting it?
Old Jan 4, 2021 | 12:48 PM
Killer-Bimmer
Amazon is where I purchased the Red Line:
Amazon Amazon
Amazon Amazon
Old Jan 6, 2021 | 04:33 PM
ForBruce's Avatar
ForBruce
Amazon inflates the prices of opti-lube and then gives free shipping....
I found "DEVINEdiesel" which has the same prices as opti-lube web site with no shipping charge as long as you spend at least $100.
I ordered opti-lube xl one gallon and summer one gallon with the extra bottles in order to make $100
I spent $8 extra to save the shipping and i will use the extra hand pump and 2-empty bottles.
Old Jan 6, 2021 | 05:23 PM
mecdac's Avatar
mecdac
Where did you go in GA? From Summerville you were probably going uphill.
Old Jan 6, 2021 | 07:14 PM
speakerfritz's Avatar
speakerfritz
I use
a lube product
a antigel product
a water demulsifier product
a water emulsifier product
a anti foam product
a anti corrosion product
and then I throw in some diesel fuel for good luck
Old Jan 7, 2021 | 09:45 AM
ForBruce's Avatar
ForBruce
always one in a bunch......
.I reset the MPG setting on the straight-a-ways to get a more accurate reading both going to georgia and back home again.
Old Jan 8, 2021 | 03:03 PM
jww694's Avatar
jww694
Hi folks! New guy here... Are the Power Service products even worth mentioning anymore? I have been running it in my 2019 F250, but that is just because that is what I have been using since 2002ish..
