2015 F350 6.7 low oil pressure light
2015 f350 6.7 getting low oil pressure light coming on I replaced the sensor above oil filter that did not fix it. Its a 2 wire sensor which is strange everyone I researched has a 1 wire sensor . The truck runs fine no strange noises so hopefully its a wiring issue
Was wondering if anyone has a wire diagram to see where that sensor wiring goes and / or any other ideas what to do next? (any other sensors I should be checking)
thanks
thanks
The 2015 only has one sensor located above the oil filter in housing thats the one I replaced its a 2 wire sensor. If u know where another oil pressure sensor is located but from all my research I cant find one anywhere
Note: If i unplug that sensor I still get a oil temperature reading on my dash so its still getting a oil temp reading from another location
