Sponsored by: Auxito
Oil Pressure Sensor?
Old Apr 27, 2010 | 11:02 AM
OSU_AGR's Avatar
OSU_AGR
I have a 2000 F-150 4.6 with 146K and when its cool or cold out after starting it up upon idle the oil pressure will drop and the light comes on. Once you touch the accelerator and speed up the RPM's just a little, the pressure jumps back up and the light goes out. After a minute or so, everthing is back to normal. It runs smooth as could be when the light comes on. Could it be the oil pressure sensor going out or something different. If anyone has experienced anything like this, let me know.
Love this site, just found it cruising around.
Old Apr 27, 2010 | 02:54 PM
rtg143's Avatar
rtg143
The sensors have failed like that. I'd get a new one and see if it continues. Oil pumps won't react like that.
Old Apr 27, 2010 | 04:27 PM
moto57's Avatar
moto57
Sensors are not that much, but before you do that clean the contacts first. That fixed mine.
Old Apr 27, 2010 | 04:47 PM
rtg143's Avatar
rtg143
I've cleaned the contacts and they worked for short while. I think the contacts inside the switch get moved around a little and they click together a little different and will quit again. The sensor is pretty inexpensive. I replaced mine after cleaning it twice. I have 153,000 miles on it.
Old Apr 27, 2010 | 05:27 PM
steve(ill)'s Avatar
steve(ill)
I believe the sensor is an on- off switch set at 8 psi. AT 7 psi it reads zero. AT 8 psi or 20 psi, it reads half scale. YOu might be just a psi or two low. If you want EXACT, you need to screw a gauge on it and see what your really got.
Old Apr 28, 2010 | 03:14 PM
Ricky B's Avatar
Ricky B
Exactly---the stock gauges are really just sexy looking idiot lights. I run Stewart Warner oil gauges on all my trucks and my boat. Been using them since the 70's in fact. They're accurate, inexpensive and close to bullet proof...........
Old Apr 28, 2010 | 04:25 PM
Flooder305's Avatar
Flooder305
I believe you're describing the built in feature of the low oil temp sensor, I could be wrong, but that's exactly what it does... Check your owners manual. I freaked one cold morning thinking I'd lost pressure when in fact it was just telling me the oil was cold.
Old Apr 28, 2010 | 04:54 PM
Ricky B's Avatar
Ricky B
Hmmm---I know on my son's MR2 turbo he has a red light for low oil pressure and a yellow light for low oil capacity, plus a good oil pressure gauge. His yellow light will occasionally light up when he hits a sharp turn at 45 mph's........
Old Apr 30, 2010 | 01:05 PM
OSU_AGR's Avatar
OSU_AGR
Thanks all, I got a new sending unit and will put it this weekend and see if that solves the problem.
Old May 11, 2010 | 01:40 PM
OSU_AGR's Avatar
OSU_AGR
Problem solved! Thanks!
~ChipsAhoy~
1997 - 2003 F150
31
Apr 26, 2019 07:58 PM
Dcnnnghm
Apr 4, 2016 05:35 PM
dborns
Escape & Escape Hybrid
54
Jan 17, 2016 01:09 PM
Thorkel
Jul 5, 2014 09:42 PM
Prozon
1997 - 2003 F150
13
Dec 24, 2013 01:36 AM
