Just wondering if anyone has had any similar issues as I am experiencing.
I am very pleased with my truck other than the oil pan leaking and my bumpers are rusting. The oil pan has a slight leak/sweating as they called it, still hasn't formed a "leak" on the ground. As for the rust, I have painted bumpers on my Platinum and 3m covering the front. It is evident that the rust is forming and pushing out the paint on both bumpers. Now they are telling me it is not under warranty.
Has anyone had similar issues??
The oil pan leak is fairly common. First thing to check is if you have excessive crankcase pressure. When the engine is at operating temp with it idling take the oil filler cap off and see if it tries to blow off. If so, you may want to address the CCV filter. As far as the rust, where are you located? Salt can wreak havoc on vehicles.
