Valve adjustment?
Old Jul 27, 2021 | 11:03 AM
RedBox88's Avatar
RedBox88
Trailering
Question Valve adjustment?
Hi yall!
I wanna know how to adjust the valves on a 1988 F-250 351w? I will change my original cam for a Comp cam 35-255-5, and I wanna know if I need to adjust my valves and if yes, how to adjust them after to install my new one?
Its a hydraulic flat tappet
Thank you in advance.
Old Jul 27, 2021 | 11:24 AM
jas88's Avatar
jas88
Depends on if the cam is solid lifter or not. If it's a hydraulic cam, which is most likely, then it adjusts automatically.
Old Jul 27, 2021 | 04:28 PM
Conanski's Avatar
Conanski
There are no valve adjustments on these motors, when assembling the motor the rocker bolts are simply torqued to spec while noting that all slack is removed just before the bolt reaches torque. If that doesn't happen longer pushrods are necessary.
Old Jul 28, 2021 | 06:38 AM
RedBox88's Avatar
RedBox88
Trailering
as its a hydraulic flat tappet ?
Old Jul 28, 2021 | 06:40 AM
RedBox88's Avatar
RedBox88
Trailering
Even if its a hydraulic flat tappet ?
What are the specs to torque ?
Thanks !
jaye
Feb 21, 2013 09:19 PM
55 f350
Flathead V8 & Flathead 6
Aug 12, 2012 11:13 PM
mpc07005
Jul 17, 2012 09:09 PM
Argess
Sep 26, 2009 02:47 PM
wagontrainer
Mar 11, 2008 09:56 AM
