AC Compressor Test?
Old Jul 26, 2021 | 09:01 AM
zedsdead's Avatar
zedsdead
AC Compressor Test?
Welp, a 16 year old pulled out in front of me Saturday night. Luckily we are all OK.
The Mazda B truck still drives but it'll need some body work before it can go back to being my daily.
In the mean time I will be driving my 88' F250.
It's been in the 90s and near 100% humidity in good ole East TN, so I want to fix my A/C in the truck. I'm sweating like a dog out here!!
Here's what I got:
Its been R134a converted.
I replaced the valves, and charged the system, but can't get the compressor to kick on. Odd note--The system read 0psi when I plugged in my gage, and quickly charged up to 40psi with not much refrigerant at all.
I can rotate the compressor by hand. As far as I can tell, it's not seized.
I have no blown fuses, and the connector is securely fastened.
The "AC" button on my center console lights up and is operational.
Is there any "force on" test I can do with the compressor? Or do I need to pull it and take it to get tested?
I have little to no experience working on AC systems. So, any help is much appreciated!
Old Jul 26, 2021 | 09:09 AM
jas88's Avatar
jas88
There is a switch on the accumulator that will not allow the compressor to come on if the charge is low. You could jump it to make the compressor run, but it sounds like you don't have much refrigerant in the system. If you have 40 psi sitting still with the compressor not running, that is almost nothing.
Old Jul 26, 2021 | 09:15 AM
zedsdead's Avatar
zedsdead
Alright, I'll pack in the refrigerant in until I get her to kick on! I will update the results tonight.
I had a leak at the high-side valve. So, I assume the system is practically empty.
Old Jul 26, 2021 | 09:43 AM
rla2005's Avatar
rla2005
Best bet is to vacuum down the system, check for leaks. Repair any of those, then refill. Jumper the low pressure/clutch cycling switch to turn the compressor on while filling.
Old Jul 26, 2021 | 11:34 AM
SFaulken's Avatar
SFaulken
I can almost guarantee you'll need to jumper the switch for the first part of your fill. I've never had one of these trucks that would get the compressor running on it's own, from a freshly evacuated state. My method is typically to hook up my gauges, and get the first can flowing, and then manually bump the compressor on and off with the jumper wire. In my experience, once you get the first full small can of R134a (I always seem to end up with the smaller cans, for whatever reason), you can generally hook the pressure switch back up, and fill normally.
Old Jul 26, 2021 | 02:41 PM
jas88's Avatar
jas88
You can avoid this if you will put the 1st can in thru the high side after your vacuum step without the truck running. This will "preload" some refrigerant in so that, when you start up the truck and turn on the a/c, the compressor will engage. It may cycle until you get the 2nd can in.
Old Jul 26, 2021 | 02:46 PM
SFaulken's Avatar
SFaulken
Huh, that might work too. Never thought about trying that.
Old Jul 26, 2021 | 03:48 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Maybe I’ve been lucky but with a good vacuum on the system it should pull enough into the system to trigger the low pressure cycling switch.
Old Jul 26, 2021 | 03:53 PM
SFaulken's Avatar
SFaulken
I would think so too. But I just did the R134a conversion on my '87, and even after I got a full can into the system through the low-side port, i still couldn't get the darn thing to cycle the compressor using the pressure switch, took about another half can before it would cycle on it's own.
Old Jul 26, 2021 | 04:43 PM
zedsdead's Avatar
zedsdead
Charged her up to 35psi and she's blowin ice cold. Thanks for the help guys.
Old Jul 26, 2021 | 07:16 PM
rla2005's Avatar
rla2005
What is the high side pressure?
Old Jul 26, 2021 | 07:18 PM
zedsdead's Avatar
zedsdead
I don't have the mating fitting for the high side unfortunately.
Old Jul 26, 2021 | 08:02 PM
My4Fordtrucks
You really should have drawn a vacuum on the system first to see if it held. That proves that there aren’t any leaks, boils off any moisture in the system and allows you to fully charge the system.
Old Jul 26, 2021 | 08:06 PM
zedsdead's Avatar
zedsdead
Worst case I wasted $20 in refrigerant. I'm pretty sure I found the leak at the high side Schrader valve.
TheKirbyMan
Sep 18, 2010 10:01 PM
302VAN
Apr 3, 2008 03:22 PM
poffutt
Mar 7, 2005 02:50 PM
Buggie
Sep 25, 2004 07:52 PM
fcarruth
1978 - 1996 Big Bronco
Jul 19, 2003 01:12 AM
