Directional signal failure
Old Jul 24, 2021 | 08:21 PM
kjmaurice's Avatar
kjmaurice
1989 F150 4x4. Very high mileage Pacific NW rig. No body rot or rust.
Direction signals are out or somewhat intermittent. All other lights, etc, work. Fuse is good. If I jump a curb the directionals will come back for that start or the day or so. Then nothing again. Short of a bad wire(?) could it be a bad ground?
How hard is it to do a wiring harness on a rig and how do you know you've got the correct one? A fishing buddy who has restored several rigs told me "the easiest way to do a wiring harness is to do a frame up resto". Well yes, but the truck doesn't need a frame up resto its in good shape. The hood could use paint. Its got a couple other issues that point toward wiring harness issues (surging idle and a misfire) of which we treated the symptoms as my Ford mechanic is stumped on the cause short of the harness(?). Any suggestions? Thanks for your help. Kev
Old Jul 25, 2021 | 08:15 AM
tjc transport's Avatar
tjc transport
i ain't rite
probably a bad flasher unit.
it is in the fusebox.
one on the front, one on the back. i don't remember which one is for blinkers and which one is for four way flashers though.
Old Jul 25, 2021 | 08:29 AM
torq'ta 5 8's Avatar
torq'ta 5 8
or switch in column-->1989 F250 Turn Signal Switch - Ford Truck Enthusiasts Forums
tubtub9677
May 18, 2015 09:32 AM
F-350PSD
Dec 5, 2014 07:52 PM
wiseguy50
Mar 30, 2007 10:40 PM
newkyford
Aug 8, 2006 10:17 PM
briansrapier
Apr 14, 2006 01:13 AM
