Did I screw up diff for good
Old Oct 31, 2003 | 12:10 PM
jeffthompson's Avatar
jeffthompson
A few years ago, the pinion seal was leaking and I replaced it and change the differential gear oil.
Instead of putting the recommended gear lube in, I went with the heaviest weight thinking that the diff would last longer.
Problem is, it's a limited slip diff and now I've noticed that traction is not what it used to be.
I need all the traction possible living in the country in Michigan with a 2wd.
Can I restore the limited slip diff by just going back to what Ford recommends or did I do permenant damage?
Old Oct 31, 2003 | 12:14 PM
LxMan1's Avatar
LxMan1
Go to the Ford dealer and get a couple bottles of friction modifier. It helps the clutches work better. After you put it in, take the truck out and drive it in a figure 8 about 8 or 10 times to work it into the clutches.
Jimmy
Old Nov 3, 2003 | 07:18 AM
jeffthompson
Thanks for the info-
Does the diff need to be drained and refilled to do the friction modifier?
Old Nov 3, 2003 | 01:25 PM
Texan1983's Avatar
Texan1983
you should put the right weight oil back in with the friction modifier.
Old Nov 13, 2003 | 12:27 AM
xlt4wd90's Avatar
xlt4wd90
If it's been a few years since you did the work, and now you're noticing that the limited slip diff is now slipping, it's very probable that the clutches are worn out. I don't normally cruise this forum, so I don't know what kind of diffs are normally used in a F150. But it's pretty easy to replace the clutch packs in an 8.8" diff. Ford sells a kit that includes two sets of clutch and steel plates, shims, some new hardware, and a bottle of the friction modifier.
Most performance oriented people will re-order the clutch/steel plates by re-using one of the old clutch plates to replace one of the steel plates.
One other note: The friction modifier is intended to actually reduce the friction of the clutches. This is to prevent them from wearing out too quickly. If your diff is slipping now, adding the friction modifier will not help. But I do agree that you should install the correct type of lube with the friction modifier. I used Mobil 1 when I rebuilt mine, and I think it's lasted longer than the factory setup.
Old Nov 13, 2003 | 10:41 AM
jim henderson's Avatar
jim henderson
Yeah, you should probably change the fluid since 1) it is old and 2) in Michigan you don't want the thickest fluid you can get.
Mix the modifier in with the fluid and get yourself one of those hand pumps to simplify putting the fluid back in. Beats the heck out of squeezing the bottle.
Good Luck,
Jim Henderson
Old Nov 13, 2003 | 11:36 AM
jeffthompson
Thanks for the info- knew you guys would have the answers.
Old Nov 13, 2003 | 07:49 PM
fordman300's Avatar
fordman300
what type of fluid does a 8.8 LSD take
Old Nov 13, 2003 | 07:56 PM
LxMan1's Avatar
LxMan1
85W90 with the friction modifier added.
Jimmy
Old Nov 14, 2003 | 10:13 AM
jim henderson
Yeah, and you will probably need 3-4 quarts plus a couple tubes of modifier. Get a new gasket while you are shopping.
When you drop the cover, check the color of the fluid. You hope it is honey or brown color. black means really old and worn out. You also want to use your finger to flip any debris out from the bottom of the case. Check what the debirs is. You don't want to see a lot of metal chunks. A few bits the size of rice are normal. There should also be a magnet, usually donut shaped. It will probably have a light coat of grey or silver fuzz, normal. metal chunks in excess is not normal.
Look at the gears. They should not have any chunks missing and they should show nice even wear surfaces, ie shiney and even over most of the contact surface. You don't want to see a lot of gears surface with heat bluing on them. they should either be shiney or in places that don't contct, they should be brownish.
Good Luck,
Jim Henderson
cwtaylor737
Nov 13, 2014 01:11 PM
05F250DSL
Feb 27, 2014 06:03 PM
jonnydz
Jul 18, 2012 04:37 PM
99explr
May 30, 2010 08:41 PM
