e4od low and reverse engaging prog
Old Nov 14, 2003 | 12:32 PM
R8R MAN's Avatar
R8R MAN
Question e4od low and reverse engaging prog
When vehicle is cold manual low and reverse engages fine, but when fluid is warmed, the only way to get low and reverse is by reving engine. When in drive range everything is fine. One shop suggested a pressure leakage in a drum or fluid passage. But if that were the case than it would not have low gear in drive without revving the motor. Could it be leaking valve body gaskets? Do the passages differ in manual slection than in drive selection for the low range?
