diff and trans case
Old May 23, 2010 | 10:02 PM
99explr's Avatar
99explr
diff and trans case
Hi, i want to change the fluid in both diffs and transfer case. i would like to know how much fluid i need and what to put in them. do both diffs take the same thing? i have a 3.55 non-limited slip. also i read that i need to take the back diff apart and put it back together with RTV. Which one do you use? Black ,blue, copper? i will be puting in synthetic so any recommendations on brand ?
Old May 24, 2010 | 01:58 AM
4.0 Beast's Avatar
4.0 Beast
I had both diffs done at the dealer and they used 75w140 with a bottle of friction modifier in each one. Not sure on the exact amounts but i think it was 3 quarts each. The rear diff is put together with RTV... any RTV would do. The dealer used black but if you bought it on your own im sure the color doesnt matter as long as its RTV. I would get the high temp one too. I would go with genuine ford oil as far as brands...... just my humble opinion
Old May 24, 2010 | 05:28 PM
steve(ill)'s Avatar
steve(ill)
your not taking the back differential apart, you taking the sheet metal pan off the back as there is no drain plug. you then glue the pan back on (and a dozen bolts) with RTV. The older trucks had 80-90 wt gear lube, non synthetic. THe newer spec is 75w-140... you can use either. You can use generic gear lube from Wal Mart if you want, dont make any difference at all.
Old May 27, 2010 | 01:36 PM
Graygeorge's Avatar
Graygeorge
My 98 exp Transfer case uses transmission fluid.
Old May 30, 2010 | 02:12 AM
99explr's Avatar
99explr
ok, changed out the fluid in the front and back diff and put in full synthetic 75w140 and changed transfer case fluid also. Went for an hour drive and checked everything when i got back. no leaks but the rear diff was so hot i couldnt keep my hand on it. The front diff was warm. is it normal for the rear diff to be so hot ?
Old May 30, 2010 | 02:22 AM
4.0 Beast's Avatar
4.0 Beast
yes im surprised you could even put your hand on it for any length of time....did you add a bottle of friction modifier to the rear diff by chance?
Old May 30, 2010 | 10:49 AM
99explr's Avatar
99explr
no friction modifier was added because my axle code is 45 which is non limited slip.
Old May 30, 2010 | 08:41 PM
steve(ill)'s Avatar
steve(ill)
i have seen more than one rear axle with the paint burnt off the cover. Why ?? i dont know, but some do get real hot.
69issofine
1983 - 2012 Ranger & B-Series
Jul 10, 2015 04:14 PM
creich68
13
Dec 28, 2010 10:31 PM
paul64
1997 - 2003 F150
Mar 17, 2010 11:10 PM
Visseroth
18
Apr 27, 2009 03:09 PM
fordf350lvr
Oct 16, 2003 11:21 PM
