Removing the bed
Old Jul 23, 2021 | 08:33 AM
460obs's Avatar
460obs
Removing the bed
Hey fellas I need to remove the bed on my 1997 f250 was wondering if anyone had any advise or possibly a diagram so I can find the bolts.
Old Jul 23, 2021 | 09:15 AM
ZSK's Avatar
ZSK
This link is a PDF download for the instructions on a body lift for our trucks. It shows the bolt locations for the cab and bed.
https://www.google.com/url?sa=t&rct=...SY3Bq9kYXSi6bd
Old Jul 23, 2021 | 09:20 AM
460obs's Avatar
460obs
Thank you that’s all I needed do you have any other advise I could use?
Old Jul 23, 2021 | 10:05 AM
GoinBoarding's Avatar
GoinBoarding
Is the truck rusty? The bed bolts like to spin when trying to loosen the nuts if rusty.
Old Jul 23, 2021 | 10:15 AM
SFaulken's Avatar
SFaulken
For my part, I usually don't bother trying to actually pull the nuts, if there's any rust at all. Just cut them. Less aggravation, and then I replace them with Galvanized Hex Head bolts. I don't care enough about the Aesthetics of the Carriage/RoundHead bolts to keep them, because they always end up being something that has to be cut or drilled.
Old Jul 23, 2021 | 10:48 AM
460obs's Avatar
460obs
Yes there is a little rust but it’s not to bad I’m going to soak them with blaster then try loosening them but if I’m going to cut them do I just need a grinder and a cutting wheel?
Old Jul 23, 2021 | 11:21 AM
SFaulken's Avatar
SFaulken
That generally works, although the front drivers side one, especially, usually has a fuel tank in the way, and can be a real bugger to get to. I usually grind the head off of that one. None of them are in nice places to get to, and there's usually wiring and/or fuel and fuel vapor lines in the way.
Old Jul 23, 2021 | 04:19 PM
EllieMae94's Avatar
EllieMae94
I had the cut 2 or 3 bolts off mine but couldn’t easily access the nuts with an angle grinder so I cut the heads off from up top in the bed. Much easier to work that way than on your back. A hammer and chisel was also needed.
Old Jul 24, 2021 | 05:22 AM
460obs's Avatar
460obs
So I replaced my fuel tank switch and my fuel gauge works now, I still need to replace my rear pump but now I don’t have to guess now.
KWDAILYD
Feb 15, 2018 10:00 AM
TobiasR.
Dec 12, 2016 01:55 PM
wreckinball
15
Jan 21, 2010 03:03 AM
dtony
Jun 6, 2005 12:18 PM
Rick2324
Feb 4, 2005 01:25 AM
