200K serive?
Old Oct 31, 2003 | 10:41 AM
KING's Avatar
KING
200K serive?
What are things you should in terms of service when you're at 200,000?
Old Oct 31, 2003 | 11:34 AM
powerstroker250's Avatar
powerstroker250
I would probably change all fluids and filters, front to rear.
Old Nov 1, 2003 | 09:31 PM
Fitzydog's Avatar
Fitzydog
Not sure if you changed you rear end fluid at 100k but it would definitely be a good idea. All you need to do is take the cover off differential, drain, clean, and replace high temp silicone and screw back together. The fill tube is at the top of the differential. I believe I put 2 qts. of Lucas rear diff. fluid. Then I flushed the coolant out but usually do that every 15k miles anyway. It is really up to you but definitely keep good maintenance.
__________________________
Aaron 99 F250 PSD CC 220,000 miles
Houston
ford f-200
17
Sep 3, 2023 09:33 PM
tjpye
Modular V8 (4.6L, 5.4L)
Sep 16, 2007 08:29 PM
TOMHONE
2004 - 2008 F150
30
Jul 23, 2007 06:50 PM
200tq
Oct 7, 2002 11:48 AM
PPestorius
Dec 28, 2001 04:04 AM
