Air Bag Codes
Old Jul 20, 2021 | 10:16 AM
mrhemi's Avatar
mrhemi
Air Bag Codes
My apologies for another thread on air bag error codes, but I have read through all I can find and not come across these exact symptoms.
'94 F150 XLT Reg. cab, Long box. 4.9L 6, 5spd. trans.
The air bag warning light will display random codes when the vehicle is running. There seems to be no rhyme or reason to the sequence. Codes 51, 23, and 24 are the most common. When I first got the truck a couple of years ago, it threw a code 51 only and all the time. The thermal fuse was replaced correctly at that time and there were no codes for about 6 months. Awhile ago the random codes started appearing, would cease, then return inconsistently. Clockspring? Although the horn and cruise control work fine. Any ideas?
Thanks in advance.
Old Jul 20, 2021 | 03:55 PM
torq'ta 5 8's Avatar
torq'ta 5 8
Check your connections, and grounds, you live in the salt belt Hiways? Corrosion
Found this,
Airbag DIagnostic Monitor (ADM) Light Flash Code (LFC) Priority Table
Tone (5 Beeps Repeated 4 Times): Air Bag Indicator Open Circuit with Stored Fault Code(s)
No Air Bag Indicator (Dash Light Out): Inoperative Indicator Circuit or No Battery Voltage to ADM
Continuous Air Bag Indicator: ADM Disconnected or Inoperative
12: Low Battery Voltage
13: Air Bag Circuit Shorted to Ground
14: Front Air Bag Sensor and Bracket Circuit Shorted to Ground
21: Rear Air Bag Sensor and Bracket Not Mounted to Vehicle Properly
22: Rear Air Bag Sensor and Bracket Output Circuit Shorted to Battery Voltage
23: Rear Air Bag Sensor and Bracket Circuit Input Feed/Return Circuit Open
24: Rear Air Bag Sensor and Bracket Output Feed/Return Circuit Open
32: Driver Side Air Bag Circuit High Resistance or Open
34: Driver Side Air Bag Circuit Low Resistance or Shorted
41: RH Front Air Bag Sensor and Bracket Feed/Return Circuit Open
42: LH Front Air Bag Sensor and Bracket Feed/Return Circuit Open
44: RH Front Air Bag Sensor and Bracket Not Mounted to Vehicle Properly
45: LH Front Air Bag Sensor and Bracket Not Mounted to Vehicle Properly
51: ADM Internal Thermal Fuse Blown Due to Intermittent Short to Ground
52: Backup Power Supply Voltage Boost Fault
53: Front Air Bag Sensor and Bracket Circuits Resistance to Ground or ADM Fault
Rapid Continuous Flashing (No Fault Code): All Primary Air Bag Sensors Disconnected
icelander_34
Sep 12, 2020 11:42 AM
im2tall33
May 5, 2013 09:21 AM
ivplay
May 29, 2011 06:58 AM
bulldog288
1978 - 1996 Big Bronco
Jun 8, 2009 11:33 AM
underDAWG
22
Jun 24, 2006 10:46 PM
