6.0 HELP
Old Jul 19, 2021 | 06:00 AM
ssssupercrew's Avatar
ssssupercrew
Angry 6.0 HELP
I have a 2006 6.0 and I rebuilt 45,000 ago and has run perfect not one issue ,the other day the gauge said low oil presure and quite running .Towed it home and checked scan gauge 2 and with icp pluged in i have 61 psi and IPR at 85% - with the ICP unpluged I have normal IPR and 1200 t on the icp . put new low oil preasure sensor and pulled and looked at IPR and it looked perfect , also I have sync and 48 on ficm did air test trough ipr and no leaks ans icp voltage .25 any Ideas also all updates were done when rebuilt truck has run pefect
Old Jul 19, 2021 | 07:34 AM
bismic's Avatar
bismic
All you do by unplugging the ICP sensor is cause the PCM to use a default value. It only helps when the ICP sensor is bad. Looks like your low ICP pressure is real.
If you have no leaks, it would have to be one of 3 possibilities:
- starving the HPOP by not feeding it sufficient oil
- bad IPR
- bad HPOP
If your HPOP is not getting enough oil to it, it could be:
- aftermarket oil filter cap with an OEM filter
- leaking oil filter housing drain valve
- stuck LPOP regulator
- bad LPOP
Does your oil pressure gauge on the dash come up when you crank for 4-5 seconds?
Remove the oil filter and crank by jumping the starter solenoid with the key off. How long does the oil filter housing take to fill up?
Since you removed the IPR, have you inspected it closely (internally) to see if anything was stuck inside of it?
What did the screen on it look like?
Did you clean it?
Old Jul 19, 2021 | 07:42 AM
ssssupercrew
- bad IPR
- bad HPOP
- bad LPOP
Since you removed the IPR, have you inspected it closely to see if anything was stuck inside of it?
Did you clean it?
I have a bullet proof diesel remote oil cooler but my low pressure gauge on the dash does not come up but I thought if I was getting 1200 psi I must have oil pressure but I’m not sure I was leaning towards the IPR being bad when I pulled it it was perfectly clean screen was not wrecked no issues as far as looking at it
Old Jul 19, 2021 | 07:44 AM
ssssupercrew
I also did an air test through the I CP and the I PR port and best I can tell I don’t have air leaks
Old Jul 19, 2021 | 08:02 AM
bismic's Avatar
bismic
What I was saying is you probably aren't getting 1200 psi ........... That is likely to be a false number.
Old Jul 19, 2021 | 08:16 AM
ssssupercrew
Well I just ordered a IPR hopefully that’s it thank you for your help I’ve been on sidelines on this site for a couple of years just observing
Old Jul 19, 2021 | 08:20 AM
bismic's Avatar
bismic
Two things -
Replacing parts without testing can get expensive.
Installing aftermarket (non-OEM) parts can also get very expensive since they fail so frequently.
Old Jul 19, 2021 | 08:26 AM
ssssupercrew
Well I did order a Ford APR valve and other than air testing the system how else can I tell if that APR is bad
Old Jul 19, 2021 | 08:31 AM
bismic's Avatar
bismic
Did you clean it?
I didn't see where you addressed the above suggestions/questions .......
You might watch the videos below
Old Jul 19, 2021 | 08:32 AM
Brotherbillstruck's Avatar
Brotherbillstruck
Also like Bismic said above-try cleaning the IPR you have. It is not difficult to do. Watch this starting at about 9 minutes
Posted at the same time
Old Jul 19, 2021 | 08:51 AM
ssssupercrew
I am a big diesel tech Ron fan it’s a shame he’s gone I didn’t take the screen off the I PR because it looked perfect and I assume if I take it off I have to replace it which is an a big deal it’s only $35 for the kit but are you telling me to take it off and see if the plunger works
Old Jul 19, 2021 | 08:54 AM
ssssupercrew
If the plunger works does that mean the APR is good or can the solenoid still be bad
Old Jul 19, 2021 | 08:56 AM
Brotherbillstruck
By flushing the valve while you hold it open you can help eliminate a mechanical failure of the valve not closing completely therefore not letting pressure build.
Old Jul 19, 2021 | 01:17 PM
CPB1's Avatar
CPB1
Sounds like a low pressure oil problem to me.
Did the oil filter housing fill up when you cranked the engine over?
Old Jul 19, 2021 | 02:22 PM
bismic's Avatar
bismic
Start with doing/answering this:
Did you clean it?
Find the yellow with light blue striped colored wire which is adjacent to the passenger side battery in the engine compartment, it is near the vacuum pump. It has a "squeeze-and-pull" type connection. Disconnect it, and jump the male end of the connector to the passenger side battery positive terminal. The starter should crank. Leave the key in the off position to just crank.
https://cimg2.ibsrv.net/gimg/www.for...4f576a8117.jpg
https://cimg6.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/960x720/80-image_e5f5072f3824a88dd5f3e5fc9c3fed4dbf37c83c.jpg
https://cimg8.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/960x720/80-image_2e79e5ce15d4581001f68628a6aeb55b1619332d.jpg
