Annoying Chime
Old Jul 15, 2021 | 02:15 PM
Rick Cargo's Avatar
Rick Cargo
Annoying Chime
I know it's there for a reason but the chime for when the door is open or the key is in the ignition is annoying. I remember on the 2011's you could remove the blue wire underneath the turn signal lever on the steering column to disable the chime. Has anybody disabled the chime and what did you have to do?
Thanks.
Old Jul 15, 2021 | 02:28 PM
Compression-Ignition's Avatar
I believe Forscan can take care of this. Can't stand that door open chime nor the double honk.
Old Jul 15, 2021 | 03:55 PM
cpobst's Avatar
cpobst
This, Forscan is the one.
Old Aug 5, 2021 | 02:42 PM
RGPolo's Avatar
RGPolo
I don't see where I can disable the key chime with my Forscan? I have also disconnected the wire in my older Superdutys, but I don't dare cut any wires on my 2019.
Old Aug 5, 2021 | 03:24 PM
riverratrusty's Avatar
riverratrusty
On mine I had to do it in the hex section. The forscan spreadsheets here in the forum cover this in detail.
Old Aug 5, 2021 | 03:50 PM
Tsubakihara's Avatar
Tsubakihara
Yes it works.
Chimes, Double Honk, and Bambi are very popular along with some of the speed correction and gauge improvements.
Old Aug 5, 2021 | 05:10 PM
AZC's Avatar
AZC
I’d like to disable the “check the back seat for passengers” chime when I shut off the truck. Is forescan required for that?
Old Aug 5, 2021 | 07:44 PM
encmerk's Avatar
encmerk
no sir. That is done through the radio. You will find a setting for rear passenger reminder. It has to be disabled every 6 months…
Old Aug 5, 2021 | 08:43 PM
AZC's Avatar
AZC
thx I’ll try that
Old Aug 6, 2021 | 09:26 AM
riverratrusty
Every 6 months, seriously? I think I'm just about to hit that mark...
Old Aug 6, 2021 | 03:38 PM
encmerk's Avatar
encmerk
when I did the last Sync update and had to turn the back seat passenger warning back off, I got a notification that I would be reminded in 6 months to turn it off again.
Old Aug 6, 2021 | 05:28 PM
Tsubakihara
I don't think my 17' or 19' had this? Must be something new, and something to look forward to?
Old Aug 7, 2021 | 02:42 AM
My 2020 doesn't do it.
Old Aug 7, 2021 | 05:38 AM
encmerk's Avatar
encmerk
your 22 will, I wager.
Old Aug 7, 2021 | 09:57 AM
RA112222
1997 - 2003 F150
Jan 20, 2011 10:21 AM
bradvuke
1997 - 2003 F150
Jan 31, 2008 02:28 PM
stucknorth
Feb 20, 2007 04:47 PM
stanphil
Nov 8, 2004 09:35 AM
jhutche
Aug 31, 2004 01:37 AM
