Sponsored by: Real Truck
Door Chime Disconnect?
Old Nov 7, 2004 | 09:27 AM
stanphil's Avatar
stanphil
Question Door Chime Disconnect?
Anyone know where the door chime/key in ignition/lights on chime is located. I always leave my key in ignition, and need to disconnect this thing before it drives me crazy. Was easy to do on my 97 ford, but cannot find it on 05' 6.0 c/c dually.
Old Nov 7, 2004 | 10:32 AM
Autobahn F-250 Lariat's Avatar
Try a search first...second goto the FAQ at the top that says read first and third below is some reading...or finally try the owners manual
https://www.ford-trucks.com/forums/s...d.php?t=304276
https://www.ford-trucks.com/forums/s...d.php?t=299887
http://www.ford-trucks.com/forums/sh...d.php?t=139080
Old Nov 7, 2004 | 04:21 PM
cangim's Avatar
cangim
There was a post on this in the 7.3L forum not to long ago, to put it short, remove the covers around the steering column, turn the key on, push a stainless ball in pull the key tumbler out, disconnect the black w/pink stripe wire from the tumbler, tape it as to not make contact, put all back together, it will still chime with the lights and a long tone when first turned on, but will not consistantly chime when the door is open.
Old Nov 8, 2004 | 08:08 AM
Brad99SD's Avatar
Brad99SD
Probably not the best way of doing it but I just take my pocket knife and trip the latch on the door and the buzzer will go off along with the dome light because the door ajar mechanism is in the latch. Just have to remember to unlatch it by pulling the door handle outside or the inside one before you close the door again. This is alot easier than tearing your collum apart. Just my $.02 worth.
Old Nov 8, 2004 | 09:35 AM
ashleymc's Avatar
ashleymc
this is driving me crazy too..how did you do it on your 97? i have a 2002 f-150 ... I HATE these safety devices....I also have a sealt belt shoulder harness that strangles me, so i use a clothespin on the shoulder belt...And for this I PAY $22,000!! anyways GREAT FORUM!!
bigcountry1009
Nov 13, 2014 08:07 AM
Adventure Rider
6.7L Power Stroke Diesel
Sep 8, 2012 01:57 PM
Etidorhpa
1983 - 2012 Ranger & B-Series
May 28, 2012 06:47 PM
amikay12
Mar 30, 2011 02:07 PM
Hotest Rod
Electrical Systems/Wiring
Feb 19, 2003 12:31 AM
