anti-lock light on..allways
THIS ONE AINT SO EASY, OK I HAVE AN 87 F150 2WD. THE ABS AND BRAKE LIGHT ARE ALLWAYS ON. ALSO WHEN BRAKING ,PEDAL PULSES AND AND TRUCK VIBRATES SLIGHTLY WHEN SLOWING FROM HIGHWAY SPEEDS...FOLLOWING WAS DONE ALREADY..
NEW FRONT ROTORS, CALIPERS , PADS ,SHIMS. I HAVE CHECKED WHEEL BEARINGS AND THERE OK.. REARS WERE ALSO DONE BRAND NEW DRUMS , WHEEL CYLINDERS, SHOES ,RETURN SPRINGS. COULD A FAULTY ABS MODULE OR MASTER CAUSE THIS TO HAPPEN ? ALL RESPONDS WILL BE ANSWERED.. THANKS
Sources of brake pulses are improper caliper installation and uneven disk surface or drum surface, you mentioned yours are all new so obvioiusly that isn't it. The warning light could be traced to a defective module or pressure differental valve. It is pretty common for the pressure differential valves to go bad from what I have been told. Let us know if you figure it out, Later
Please don't post in all caps, it takes longer to read it.
You need to work on the problems indicated by the red brake light first, it indicates mechanical or hydraulic problems and it may be dangersous to drive the truck.
Just because all of the work has been done it doesn't mean that the work was done right, people make mistakes, some new parts are defective.
You mentioned a vibration, do you feel it through the steering wheel or through your seat? this may indicate whether the problem is in the front or in the rear.
i havent had a chance to work on the brakes cause my fuel pump went on friday night ....really pissed me off to cause i got stuck in middletown nj and i live a nearly 100 miles from there. but i hope to work on them next weekend...god willing nothing else goes on the truck...hey i shouldnt really complain. i have 252,000 miles on this truck..org engine, org trans...runs like a champ too.)
alabama5428
02-26-2017 04:19 AM
crandallf150
12-03-2016 08:48 PM
mike L
02-27-2016 04:57 AM
speleausmining
1983 - 2012 Ranger & B-Series
02-19-2010 12:20 AM
