no ABS brakes and no warning light - Ford Truck Enthusiasts Forums
Old 02-27-2016, 05:57 AM
mike L mike L is offline
mike L is starting off with a positive reputation.
I have no ABS brake pulsing effect when braking hard, also the ABS warning light is not on. When I turn the key on the abs warning light comes on so the bulb is good. The brakes good work on pavement.
I have had no ABS brakes, for about a year. Why is the ABS warning light not coming on?
ABS RSC Warning Light Power Stroke 7107 Explorer, Sport Trac, Mountaineer & Aviator 8 01-17-2018 08:37 PM
ABS light, and brake light on stan'37 1999 to 2016 Super Duty 1 10-24-2017 03:52 PM
ABS Hydraulic Unit Bleeding gvgstngreg 1987 - 1996 F150 & Larger F-Series Trucks 3 03-27-2017 04:05 PM
97 350 brake code 12 problems mcali2 Brakes, Steering, Suspension, Tires, & Wheels 0 07-28-2016 12:13 AM
2007 F150 ABS brake problems lavigeboy27 2004 - 2008 F150 0 03-25-2016 07:36 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
