ABS
Old May 30, 2015 | 01:40 AM
FordRun's Avatar
FordRun
ABS
new drums new spring kits new wheel Cylinder new Master Cylinder . still wheels lock up. could it be a ABS Hydraulic Unit ? done change the ABS Speed Sensor wheels lock up when I hit brakes done been bleeded front ok. just rear
Old May 30, 2015 | 01:48 AM
FordRun's Avatar
FordRun
re
for got to add. its on a 94 f150 4x4 5.0 auto trans tow package no 5 feet wheel ball tow only
Old May 30, 2015 | 01:49 AM
FordRun's Avatar
FordRun
1 more thing its a xl
Old May 30, 2015 | 02:04 AM
FordRun's Avatar
FordRun
re
friend put in spring kit not sure if its right or not when I wake up I will do a video I pull drums off on both wheels so you can see it. my truck been sitting for month need it fix ty for any advice
Old Jun 2, 2015 | 07:06 PM
FordRun's Avatar
FordRun
re
replaced Hydraulic Unit abs. if i start truck hit brakes rear wheels still lock up. new drums new spring kit new shoes i have crack open bleeder for wheels be unlock . any help please ty
Old Jun 2, 2015 | 08:58 PM
Conanski's Avatar
Conanski
Are you saying the rear wheels lock and don't let go when the brake is released? If so start by replacing the rubber flex line from the chassis to the axle and if that doesn't fix it replace the ABS module.
Old Jun 3, 2015 | 01:34 AM
FordRun's Avatar
FordRun
yes rear brake lock up after i let off pedal . so if i bleed lines wheel they turn when i start truck touch brakes they are lock up
Old Jun 3, 2015 | 03:36 AM
timbersteel's Avatar
timbersteel
I agree with Conaski on the rubber flex line. It is just under the bed, near the rear axle. When this line swells inside, it doesn't allow the fluid to release causing problems you have mentioned.
Old Jun 3, 2015 | 04:30 AM
David7.3's Avatar
David7.3
If the line didn't internally collapse try loosening the rear line on the master and see if it releases then, sometimes on after market masters they use bigger seals and it doesn't past the opening keeping pressure in the system, I have seen it on the front brakes as well as the rear, but it does sound like a hose, I have seen people vice grip the rear hose while replacing wheel cylinders so fluid doesn't make a mess that is the death rattle of the hose. they make a tool to clamp off the line without damaging it. Start there than work your way forward till you find the blockage.
Old Jun 3, 2015 | 11:16 AM
FordRun's Avatar
FordRun
its 10 am will have wait get the part later today. flex hose. when get new one in will update . been sitting past month cause we keep buying this and that for truck. i did see that abs relay has been taken out and 30 amp fuse out to. i just put new ABS Hydraulic Unit in. the abs light never been on. only when starting truck went out. i like to thank you all for advice.
Old Jun 4, 2015 | 01:38 AM
FordRun's Avatar
FordRun
update. put in a new rear flex hose still rear brakes are lock up . undid all abs still lock up . open bleeder they turn. when you start it touch brakes . they lock up again. now thinking run a straig line from Master Cylinder to rear or tie in from Master Cylinder do away with the abs unit. any help ty.
Old Jun 4, 2015 | 01:44 AM
FordRun's Avatar
FordRun
also where is ABS module on 94 f150 4x4 5.0 auto trans xl cruise controll ,? ty we did bleed the system
Old Jun 5, 2015 | 01:30 PM
FordRun's Avatar
FordRun
turn out was bad Master Cylinder. ty
Old Jun 6, 2015 | 05:44 PM
rla2005's Avatar
rla2005
Thanks for the feedback!
ihaul
Jan 2, 2019 01:35 AM
hughjazz
Dec 19, 2013 01:09 PM
4Ranger4
1983 - 2012 Ranger & B-Series
Feb 27, 2011 09:03 AM
F150 Angry Man
1997 - 2003 F150
Feb 9, 2007 01:33 PM
demalagutti
Jul 25, 2006 08:32 PM
