2015 5.0 Code P0455
Old Jul 14, 2021 | 05:17 PM
Ragnar Ranger's Avatar
Ragnar Ranger
2015 5.0 Code P0455
I have a 2015 F150 XL with a 5.0 and a little more than 382K on it. My CEL keeps lighting up and telling me Check Fuel Cap. My truck is the model that came with "no" fuel cap. Code P0455! Large leak detected. How do you check fuel cap if you don't have one? lol. After reading several posts about my possible problem I have replaced the purge valve last week and cleared the code. The light did go out, but my scanner, which is a Launch C Reader V+, tells me the code is still in the system and it failed to remove the code. The light hasn't come back on,"yet", but I am expecting it to soon. I have since purchased a new purge solenoid and have a new canister on order. It should be here tomorrow and I'm hoping to replace them this weekend. Is there anything else that I could be missing other than a kinked or plugged line somewhere?
Old Jul 15, 2021 | 09:24 AM
alloro's Avatar
alloro
The P0455 code means a large leak for which a loose gas cap is the usual suspect, but it doesn't mean it is definitely a loose gas cap. The easiest way to find a leak is to use a smoke machine because wherever you see the smoke, that's where the leak is.
Old Jul 15, 2021 | 09:36 AM
Bluegrass 7's Avatar
Bluegrass 7
The auto sealing cap function is not sealing.
At the mileage you have, I would expect it some time.
A lot of gas fill nozzles have been stuck through it.
Old Jul 15, 2021 | 12:19 PM
Ragnar Ranger
Is there a fix? Or am I going to need a new tank?
Old Jul 15, 2021 | 12:23 PM
Ragnar Ranger
Is there a fix? Or, am I going to need a new tank?
Old Jul 15, 2021 | 02:21 PM
jr105's Avatar
jr105
You can check whether the auto sealing cap is leaking by putting a piece of solid plastic tape over it and seeing if the problem goes away.
SC_Hoaty
Oct 10, 2014 07:49 PM
beerguy5812
Jun 2, 2009 12:59 PM
4.0 Beast
Sep 25, 2006 11:13 PM
jstang95
1997 - 2003 F150
Feb 21, 2005 09:24 PM
330design
1997 - 2003 F150
Jun 28, 2004 09:56 PM
