Sponsored by: Real Truck
Transmission
Old Jul 14, 2021 | 05:00 PM
klausd's Avatar
klausd
Transmission
I am having issues putting my truck into park and it staying in park. Fluid is fine, any ideas?
Old Jul 14, 2021 | 06:14 PM
Fefanatic's Avatar
Fefanatic
You don't say what truck you have but if it won't stay in park that would be a linkage issue and not a fluid issue. Does the shift lever feel loose?
Old Jul 14, 2021 | 09:00 PM
klausd's Avatar
klausd
Its a 1999 f250 superduty and yes the shift lever is real loose, i plan on replacing it
Old Jul 14, 2021 | 10:32 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The loose shifter is the problem. There are two #30 Torx bolts that hold the shift cable to the shift tube at the bottom end of the steering column. If these are loose or missing they will cause the problem you have.
Old Jul 15, 2021 | 09:12 PM
klausd's Avatar
klausd
Worked like a charm, still have a little wiggle but better than before. Thank you
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Oct 26, 2017 07:29 PM
irydasteelhorse
Mar 9, 2017 09:13 PM
tommyl
Dec 4, 2015 11:33 AM
michaelskerrett
Jun 25, 2014 11:18 AM
