Sponsored by: Real Truck
Temp sensor
Old Jul 10, 2021 | 09:58 AM
blackBetty2008's Avatar
blackBetty2008
Temp sensor
I have a 2008 super duty with 6.4, have a problem with the temp and oil sensor. Changed my radiator and replace the sensors in the mean time. And my check engine light is still on for both, don’t know what to do now. I know with the temp sensor my fan constantly runs and I burn more fuel. Any help???
Old Jul 10, 2021 | 12:55 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
What codes are you getting? Some codes say the reading from the sensor is bad, some codes say there is an electrical circuit issue. If a new sensor doesn't fix the problem, it usually means there is a fault in the wiring between the PCM and the sensor.
Old Jul 10, 2021 | 01:11 PM
blackBetty2008
I have codes P0198 engine oil temp sensor high
and P0118 engine coolant temp sensor 1 circuit high.
Old Jul 10, 2021 | 04:28 PM
Mark Kovalsky
I suspect you have a damaged wire between the sensors and the PCM.
Old Jul 11, 2021 | 07:32 AM
Fefanatic's Avatar
Fefanatic
Pull the E connector at the pcm and measure resistance between pin 2 and ground. If less than 10k ohms the wiring to the oil temp sensor is damaged somewhere. For the ECT pull the E connector at pcm and check resistance between pin 2 and pin 67. If less than 5k ohms the circuit is open.
Old Jul 11, 2021 | 07:44 AM
Mark Kovalsky
If the circuit is open it will show infinite ohms, which is more than 5k ohms.
Old Jul 11, 2021 | 12:47 PM
Fefanatic's Avatar
Fefanatic
Yep, brain fart. I should have posted that if open check the wiring. Sometimes my dyslexia sets in. That and altimers.
Dalton2413
2009 - 2014 F150
Feb 24, 2025 07:58 AM
rgarrett
Aug 23, 2010 10:47 AM
bullit340
Sep 11, 2007 04:06 PM
99 Expy EB
Dec 26, 2006 09:50 AM
mchild
May 28, 2005 02:53 PM
