Sponsored by: Real Truck
Spare Tire Replacement
Old Jul 9, 2021 | 04:24 PM
kurthb's Avatar
kurthb
Pondering replacing my spare tire, it's original to 2006. I replaced the rims, so I can pick the best ones to use rather than the "spare tire" rim.
So the question is, do I just go with a inexpensive tire that meets the needs or go with what matches what is on the truck?
I usually don't worry about the spare per say but since I tow a 5th wheel I want to be safe if needing to run on spare while towing.
Old Jul 9, 2021 | 04:59 PM
Joe T's Avatar
Joe T
Since you have to get a new tire whatever is cheapest in your size…
Old Jul 10, 2021 | 07:45 AM
MisterCMK's Avatar
MisterCMK
I've got better things to spend money on than a new spare tire that's going to sit under the pickup for the next 20 years. My spare is the original 17-in wheel and tire that came with the pickup. it's definitely smaller than 35s that are on there now but I've never had it on either.
Old Jul 11, 2021 | 10:45 AM
5851a's Avatar
5851a
Flats used to be more common. If you have traction lock rear you will need a spare the same diameter as your other tires, and if towing a load you need same weight rating to support load. Thank you for a memory jog, my spare is now 9 years old and I should look for replacement. Changing a tire is one thing but buying a tire 1000 miles from home is another.
Old Jul 12, 2021 | 06:55 PM
RigCity's Avatar
RigCity
Bought my current (4) wheels used way down the road I’ll buy 5 matching ones new. It’s nice to have 5 tires in rotation.
Old Jul 13, 2021 | 10:27 PM
reptar0077's Avatar
reptar0077
Like he said the load rating you want to match & same size tires as on truck as most of us are running 2 sizes or larger on our trucks.
I know for a fact you can fit a 285/75 under on my old 03 spare tire spot just barely, but it does fit.
I actually just had mine replaced as it was the original & 18 years of rubbing on the spare tire rack didn't leave me feeling reassured.
I called up my local tire store & asked for a customer take off/ used tire & ended up getting it for like 40$ mounted and balanced.
Old Jul 14, 2021 | 06:55 AM
Joe T's Avatar
Joe T
Assuming you never haul/tow very far away from home especially after normal business hours.
Old Jul 14, 2021 | 08:47 PM
EDC8008's Avatar
EDC8008
I typically when ever I change tires, I take the best tire I'm taking off and swap it to my spare. This typically keeps with a spare that's only 3 to 4 years old. I also don't worry about the wheel for my spare but after my last trip through KC and getting a flat on my Coopers (piece of Flint through the center of the tread) found I needed a new set anyway.
The spare was a TOYO, same size and rating but was over 8 years old.
I do need to drop the spare and do some cleaning and preservation as I've been neglectful.
Old Jul 15, 2021 | 07:46 AM
MisterCMK's Avatar
MisterCMK
Hundreds of miles from home nights and weekends. The spare holds air and isn't cracked. I have better things to waste money on.
Old Mar 16, 2025 | 06:55 AM
Timtraci's Avatar
Timtraci
1st Gear
this has been a good reminder. I need to check my 24 F250 Lariat spare. Would like them all to match for additional life a 5 tire rotation provides in addition to the benefit of a same sized tire should I have a flat.
Old Mar 16, 2025 | 03:48 PM
marksman76's Avatar
marksman76
I have the original spare since production date 03/2001.
I only took it down once to rehearse the procedure while on my driveway.
I strongly recommend the rehearsal to all.
Old Mar 16, 2025 | 04:42 PM
Eman85's Avatar
Eman85
Most never even bother to check the air in their spare until they bolt it on and it's flat too.
LAs SUV
Escape & Escape Hybrid
Mar 16, 2025 11:25 AM
dsamuels
2015 + Expedition & Navigator
May 25, 2021 09:58 AM
Squirly
May 10, 2021 12:32 PM
USCG_PA
Feb 23, 2016 05:12 AM
cghstrojan08
2009 - 2014 F150
Jan 10, 2016 07:28 PM
