Granted, my vehicle is an Expedition and different engine, but I installed a Fujimoto oil drain valve. When I change the oil I can slip a piece of vinyl tubing over the drain valve spout and put the other end of the vinyl tubing in an old 5 gallon plastic jug. THEN open the oil drain valve. Haven’t spilled a drop!
Me too on my 3.5. Best money I've ever spent, and the filter is a breeze too. My hope is next oil change to reach up behind the diaper and pull off the change even easier.
Here is a video review I did on the Ronin. I do like it, but I have a few things I would change about it. Its well built (and in the USA) from solid aluminum. It seals well and looks good. Its a tad expensive, but worth it in my opinion. My biggest gripe is the tool you have to use to drain the oil. I always seem to forget where I put it, and it has sharp corners that hurt your hand if youre not wearing gloves. However, it does has a nipple for a hose which makes draining mess-free. I highly recommend it. I have not used the UPR but it is very similiar. I also currently have a Fumoto prototype plug, but they are pulling the plug (pun intended) on the product.
Just installed the Ronin on my 2018 2.7EB at the last OCI. I can confirm it is a well made piece of anodized aluminum that exudes quality. I think its absolutely abhorrent that the OE drain plug design almost requires this upgrade and the expenditure of $80 though. While the factory plug worked I found it overwhelmingly messy and that ANY cross breeze would substantially increase this mess. Can't say how well the Ronin will work for drains in practice as I have not hit my first OCI with it yet but I cannot see how it wouldnt work well. I did think about the UPR version, and I'm sure its great, but I just preferred to have a outer cap backing up the valve itself.
