Fumoto Oil Drain Valve Yes or No! - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Reload this Page >
Old 01-30-2005, 07:13 PM
TBag7295
TBag7295 is offline
TBag7295 is starting off with a positive reputation.
Can you guys give me a little feedback on the Fumoto Oil Drain Valve. I am waiting to change my oil but want to know if I should install one or not.
Thanks for the feedback.
Tony
Old 01-30-2005, 07:36 PM
photonv
photonv is offline
photonv is starting off with a positive reputation.
Thumbs up Con's ??
I would see very little reason not to install a F valve if you do your own oil changes. the only remote chance would be to have someone drain oil on you?? unless they cart off four gallons then you would see it on the ground. I have had valves on my pu trucks for at least five years never a problem. I used to be a fleet mechanic for high trucks( 18 wheelers) they used them never heard of a problem
barnbridge's Avatar
barnbridge
barnbridge is offline
barnbridge is gaining momentum as a positive member of FTE.
Smile
yes, almost makes oil changes fun!
Old 01-30-2005, 07:58 PM
IB Tim's Avatar
IB Tim
IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
ONLY thing to have if you do it yourself....well OK, and some oil, and a filter and ........
Old 01-30-2005, 08:21 PM
04superduty
04superduty is offline
04superduty is starting off with a positive reputation.
just used mine for the first time. no oil splashed anywhere. i got the one with the nipple and it drained alittle slow. I am not sure of the one without the nipple drains any faster. the fact that no oil was splashed made up for the slow speed. Also not needing a wrench to remove the plug was nice.
Old 01-30-2005, 08:31 PM
Steina
Steina is offline
CO River Rat
Steina is gaining momentum as a positive member of FTE.Steina is gaining momentum as a positive member of FTE.
Lowered vehicles and/or oil drain plug on bottom of pan - no.
Other than that, go for it!
Steve
Old 01-30-2005, 09:35 PM
Antacus
Antacus is offline
Antacus is starting off with a positive reputation.
So do these plugs allow the trash from a new truck to drain out or wait for past the first few oil changes to add them?
Old 01-30-2005, 09:51 PM
SBV45's Avatar
SBV45
SBV45 is offline
SBV45 is gaining momentum as a positive member of FTE.SBV45 is gaining momentum as a positive member of FTE.
I put a Fumoto valve with nipple on the first oil change. I have a 4x4. It is on the bottom of the pan. I have had it out in the bush, mud, etc. It is well protected by undercarriage and front anti-sway bar. You would have lots of other problems if you managed to rip it off.
It seems to drain out everything.
I have over 30,000 miles which means I have done 5 oil changes with the Fumoto. It makes life easy. I just drain into some old gallon oil jugs that I dispose of at AutoZone.
Get one. Put it on.
Old 01-30-2005, 09:55 PM
Antacus
Antacus is offline
Ahh, good idea. I was wondering where I was going to find a 3+gal oil pan. So far the biggest I have seen is 12 quarts, which leaves NO room for extra.
Old 01-30-2005, 10:00 PM
SBV45's Avatar
SBV45
SBV45 is offline
I save a set of my old gallon oil jugs. I buy it by the gallon. With the fumoto you empty right into the jug, turn it off, change the jug, etc. The old oil jugs have a clear line going up the side so you can see how much oil is in the jug so you don't overfill.
Never spill a drop.
Old 01-30-2005, 10:29 PM
jackofalltrades
jackofalltrades is offline
jackofalltrades is gaining momentum as a positive member of FTE.
Buy the Fumoto. Great on a 4x4!
Yes, it's a little slow to drain. I use one gallon clear plastic milk jugs, easy to glance under the rig to see if I need to move another in place. My garbage/recycling service picks up the jugs for proper disposal. I've never tried to pour 14+quarts from an oil drain pan into containers. Sounds like a challenge. The Fumoto valve with nipple makes things easy and mess free. As far as letting metal through.. If there's stuff flowing that's bigger than which will fit out the valve, I'd figure you'd see traces of the same in your filter which is quite inspectable when you change it. If you've got that much metal in your oil, you've got other prollems...
When you install the valve do it with cold oil. (unless your thumb is impervious to pain), Just pull the plug, then quickly plug with one of your digits, then quickly install the Fumoto valve, Next oil change -do it when the engine's warm. It'll flow a bit faster then.
Old 01-30-2005, 10:33 PM
kabcpapc
kabcpapc is offline
kabcpapc is starting off with a positive reputation.
Just did my oil change on 1-27-2005 and installed the Fumoto valve with nipple so I can use 3/8" ID clear tubing to rout the oil drainage where I want to. The oil filter is still the messy part but I might investigate the Oil Guard system to see if I can eliminate more mess.
Old 01-30-2005, 10:39 PM
SBV45's Avatar
SBV45
SBV45 is offline
How is the filter messy? When I unscrew the cap, I lift filter and cap out and use a plastic shopping bag to set it in and grasp the filter with the bag then just wrap the filter in the bag for disposal. If you loosen the filter cap but not remove the cap and filter, it will all drain into the crankcase while you drain the crankcase.
Check the oil change procedure in the .....Tech Folder........
Old 01-31-2005, 02:20 AM
OSBUCKEY
OSBUCKEY is offline
OSBUCKEY is starting off with a positive reputation.
Who sales the Fumoto drain valve and where can you get one. Sounds like it would be good for sampling your oil.
thanks
Old 01-31-2005, 06:09 AM
dsweger's Avatar
dsweger
dsweger is offline
dsweger is starting off with a positive reputation.
Although I have a Fumoto on the way for the next oil change, you can buy an oil drain pan at Walmart which holds the old oil easily.... It even has a pour spout on the side to make getting the oil into other containers easy.
Quick Reply: Fumoto Oil Drain Valve Yes or No!
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
