Oil pan replacement
Old Jul 20, 2021 | 02:27 PM
4drocket's Avatar
4drocket
@Edward Michael funny but not related to idi i once told a buddy i wanted to tighten up the floor in my kitchen (stop the creaks) as i was gonna lay down new sub floor and vinyl flooring, he got all pissed off telling me "thats not the right term..." blah blah blah weird how people wanna get so worked up over words
Old Jul 21, 2021 | 11:53 AM
Charmalu's Avatar
Charmalu
You can delete the Oil Cooler. but where are you going to mount the Oil Filter?
The Filter screws onto the rear of the OC.
You will need the 4 "O" Rings and the 2 paper gaskets.
and you will have to lift the engine on the drivers side to slide the OC to the rear.
Have fun getting to the front 4 bolts.
I did a thread on it and the fun I had.
I did this job 3 years ago in January between snow storms......out side under the
patio cover.
A few winters back my Water pump started leaking, I had a shop do that job as I
wimped out doing it in the cold. they mentioned the VC were leaking, so had them
replace the gaskets. Nice to have it cleaned up.
About 6 mo later the left side started to weap oil. I pulled each bolt one at a time,
blew out the with carb cleaner and compressed air. Then used blue loc-tight on
the bolts. Drivers side still petty clean, but Pass side is a oily mess which I didn`t do.
Charlie
Old Jul 22, 2021 | 07:50 AM
RaymondIV's Avatar
RaymondIV
the bolts.
Yessir, I just ordered VC gaskets a couple days ago, mine are the originals and finally seeping although the bolts are tight. Seems like anytime I had the valve covers off over the years I had to re-tighten the bolts also, usually twice. Think I'll go the LockTite route too.
Old Jul 23, 2021 | 12:12 AM
Edward Michael's Avatar
Edward Michael
OP.....ya got some vets replying here to yo thread.....take note!-)
this thread started as changing oil pan and now oil cooler and valve covers and still thinking that rearmainseal...
and torqued the rods and.....
pull the engine and tighten it up dude!-)
how about that rear main seal tjc....whats your take on that thing?
Old Jul 23, 2021 | 12:33 AM
Edward Michael
And 4drock....dunno what tagged is but your it!-) ..... and yes getting worked up bout dudes worked up about terms and conditions and OP’s that skip out and cut corners......wait....thats me....oops. There I go again.
Old Jul 23, 2021 | 03:53 AM
tjc transport's Avatar
tjc transport
i ain't rite
i have never messed with a rear main seal on the idi.
Old Jul 23, 2021 | 11:36 PM
Edward Michael
Roger that tjc. It’s over for me than. Thanks!-)
padd54
Nov 9, 2012 07:36 AM
wicat3
Jan 22, 2012 09:17 PM
johnsteffy
23
Sep 22, 2010 07:23 PM
jbilliel
Connecticut Chapter
Jul 31, 2009 11:13 AM
TheBlueMule
Sep 25, 2008 10:16 PM
