Oil pan replacement
Old Sep 21, 2010 | 10:00 PM
johnsteffy's Avatar
johnsteffy
Oil pan replacement
so today while looking under my truck i found a nice patch on the oil pan. i guess the oil pan rotted out and the last guy just rigged it up to sell it. whats my best bet for an oil pan? any one that hold more oil?
Old Sep 21, 2010 | 10:04 PM
fordpride's Avatar
fordpride
no bigger pans that i know of/ is the pan leaking if not i wouldn't touch it it's a real PITA to change
Old Sep 21, 2010 | 10:06 PM
johnsteffy's Avatar
johnsteffy
well, i just dont want this thing to let loos one day. i only have 100k on my truck and i am always down to learn how to do something new on my truck
Old Sep 21, 2010 | 10:12 PM
Brain's 97 Diesel's Avatar
Brain's 97 Diesel
From all that I've heard you have to pull the motor to replace the pan. I'd clean it off and seal it up. Start looking for a pan. I can always find stuff cheap when I don't need it and for a lot of $ when I do need it.
Old Sep 21, 2010 | 10:15 PM
johnsteffy's Avatar
johnsteffy
thats what ive heard to. it is sealed fine without any leaks or anything but i really need to get a new pan
Old Sep 21, 2010 | 10:19 PM
fordpride's Avatar
fordpride
you might beable to just lift the motor to change it but i'm not sure if that will give the room you need to get it out
Old Sep 21, 2010 | 10:22 PM
C350CREW's Avatar
C350CREW
I had a 91 f350 cc with a 460 auto. it needed an oil pump and everybody told me i would have to pull the motor. I jacked up the truck and supported it at the frame to allow the front axle to sag as far as possible. then i jacked the motor up as far as possible and the oil pan came off. dont know if this can be done on the 7.3 but i would sure give it a try before i pulled the motor.
i agree with Brain's 97 Diesel, clean it, patch it, and start looking for a replacement pan.
Old Sep 21, 2010 | 10:23 PM
chicagodragon's Avatar
chicagodragon
there was a thread on this a while back where they cut the crossmember out, then welded it back in
Old Sep 21, 2010 | 10:48 PM
Brain's 97 Diesel
I'll pull a motor before I cut out & reweld a crossmember, and I have the tools & ability to weld.
Old Sep 21, 2010 | 11:15 PM
chicagodragon
i thought the same thing, but if you find and read the post... there is not nearly as much stress on it as you would think
Old Sep 22, 2010 | 05:51 AM
427 fordman's Avatar
427 fordman
I read someone on here did this not too long ago, don't remember who though, so yeah, it can be done with the 7.3
Old Sep 22, 2010 | 08:20 AM
Action4478's Avatar
Action4478
Cuda Jim had a nice write up on it ...
The reason the engine has to come out , is the sump is bolted to the front cover .
Old Sep 22, 2010 | 08:32 AM
rideracelivemx7's Avatar
rideracelivemx7
ford had a Jig made up from what i was told so they didnt have to pull the motor, it can be done but its a PITA! the reason you should pull it is because if you dont silicone right and it leaks, it will leak like a pig. just loosen the motor and other mounts and jack the motor up high as possible, it should squeak by but its not going to be fun.
Old Sep 22, 2010 | 08:50 AM
johnsteffy's Avatar
johnsteffy
I'm going to just try loosening all the mounts and hoisting it. hopwfully it works...
Old Sep 22, 2010 | 08:56 AM
97250hd-earl's Avatar
97250hd-earl
Chicagodagon- george, the thread on the crossmember cut was by strokin-tatsch- travis.
