Vibration
Old Jul 7, 2021 | 02:19 PM
Gwilkrrs's Avatar
Gwilkrrs
Vibration
So I recently got new tires, truck running g smooth- 2k miles later I have picked up a slight vibration I noticed while hauling our 5th wheel rv.
unloaded I still feel it but not as bad as under load- seems like around 48-50 then goes away at 60?
how much if any play does the carrier bearing have? I choked wheels and put in neutral and pushed on driveshaft and it moved but not a bunch- not sure how to check sealed u joints either-
wheel weights all look like they are still there-
2 piece drive shaft 2017 f350
Old Jul 7, 2021 | 03:27 PM
aboyles's Avatar
aboyles
My guess would be you slung a wheel weight off. If you feel it in the seat and not the steering wheel it is probably the rear. I would suggest a tire rotation and balance. If problem goes away, then its solved. If it moves to front with rotation then its still a tire but now you have narrowed it down a little. If it's still there with no change, dig deeper.
Old Jul 7, 2021 | 06:25 PM
cficare's Avatar
cficare
DRW? Rock stuck between a pair?
Old Jul 7, 2021 | 06:45 PM
Gwilkrrs's Avatar
Gwilkrrs
Sorry single rear wheel CCLB
pwjackson42
36
Jun 17, 2022 05:26 PM
Franko72
50
Feb 21, 2013 08:21 PM
whf
Jul 27, 2010 12:11 PM
EMD_DRIVER
15
Jan 19, 2009 04:57 PM
Dog_Driver
Nov 26, 2005 12:28 PM
