Vibration can't figure it out
Old May 25, 2021 | 01:45 PM
pwjackson42's Avatar
pwjackson42
Okay so truck has a vibration and not like a tire out of balance or wheel bearing. I have recently had the tires balanced and rotated, new drive shaft ujoints and carrier bearing. Everything underneath seems tight and I have had my mechanic check things over and dive it. It is a vibration that you feel in your butt not just the steering wheel. You can start to feel it at about 35 to 40 mph. When not towing you subsides after about 45 mph. When I am towing my 5th wheel the vibration is much worse and can be felt at speeds 35mph and above. Does not seem to be RPM related. Any help or thoughts of what to check for would be great.
Old May 25, 2021 | 04:06 PM
FinnishStroker's Avatar
FinnishStroker
Can you perform a buzz test to rule out possible silent injector?
Old May 25, 2021 | 04:08 PM
96 OBS's Avatar
96 OBS
Death wobble? Have you replaced sway bar bushings? Made a world of difference on mine
Old May 25, 2021 | 09:18 PM
Jarrett Campbell's Avatar
Jarrett Campbell
I have the same on my truck but it happens 65-70. Not below or above that speed.
Old May 25, 2021 | 09:38 PM
iverger's Avatar
iverger
If either of you are manual, I had a vibration noticeable in 1st when I towed heavy and all the time, even empty, between 65-70 mph in 5th.
It turned out to be a broken clutch spring
Old May 25, 2021 | 11:04 PM
oldbird1965's Avatar
oldbird1965
My injectors all buzzed out but it was the contribution test that showed a dead injector.
Old May 25, 2021 | 11:13 PM
96 OBS's Avatar
96 OBS
I’m a little confused. Does it seem to be the engine vibrating or something with the truck?
Old May 26, 2021 | 12:57 AM
FinnishStroker
To me it was clear that he has rule out the chassis.
When i had a broken armature screw in one cylinder,so I was running on 7 only,my first thought was that driveshaft ujoint was shot.
Vibration was heavily amplified under load.
Engine vibration does shake the steering wheel under load but not like when having a death wobble.
Old May 26, 2021 | 07:25 AM
pwjackson42
I don’t think it is engine related. It’s like the whole truck shudders/vibrates. When not loaded or towing it is noticeable between 35-45 mph and doesn’t matter what rpm. Will do it in 4th gear or 5th at that speed.
Old May 26, 2021 | 07:26 AM
pwjackson42
My truck does not have a front sway bar. Was wondering if it could be an alignment issues or shocks?
Old May 26, 2021 | 07:45 AM
FinnishStroker
Sloppy shocks can do whatever and alignment never hurts.Driveshaft out of balance after ujoint swap?
When engine fibrates for real,it does shake whole vehicle.
Noticed any loss of power?
Old May 26, 2021 | 11:09 AM
pwjackson42
no power loss and it did this vibration before the ujoints and carrier bearing was replaced. That was the reason for doing those. The carrier bearing was pretty sloppy but must not have been the issue.
Old May 26, 2021 | 02:42 PM
97-psd's Avatar
97-psd
How old are the tires? Any chance you have a broken belt?
Old May 26, 2021 | 03:59 PM
pwjackson42
they are new, just had them all balanced to.
Old May 27, 2021 | 12:28 PM
pwjackson42
Well driving the truck today it almost has to be chassis related. The vibration feels like you are driving over a corrigated road when between 35 and 45 mph. Doesn’t matter what gear or rpm. I even threw it in neutral and still the same thing. I scheduled an alignment for next Wednesday so maybe that will solve something or they can tell me what’s wrong.
