Vibration on acceleration
Old Jan 14, 2009 | 08:39 PM
EMD_DRIVER's Avatar
EMD_DRIVER
My 93 has been having a vibration, but it's only when I'm accelerating. Once I let off the pedal, it stops. I was under the assumption that it was a U-joint going, but all three of them are still tight. I'm curious to know if it could be the carrier bearing, that is making the vibration. The only play I have in the rear driveline is in the carrier bearing itself. If I move it up and down, I can hear a rubbery sloshing sound.
Thanks for the help!
Gary
Old Jan 14, 2009 | 08:46 PM
joe f350's Avatar
joe f350
is ur drive shaft balenced and the same with ur tires
Old Jan 14, 2009 | 08:49 PM
EMD_DRIVER's Avatar
EMD_DRIVER
Everything is balanced. I didn't find any missing wheel weights on any of the 4 wheels.
Old Jan 14, 2009 | 08:51 PM
joe f350's Avatar
joe f350
tire alinment
Old Jan 14, 2009 | 08:53 PM
joe f350's Avatar
joe f350
or a motor mount
Old Jan 14, 2009 | 09:03 PM
EMD_DRIVER's Avatar
EMD_DRIVER
I just had the front end aligned a month ago and the problem started well-after that. Also, it is coming from the rear driveline.
Old Jan 14, 2009 | 09:07 PM
joe f350's Avatar
joe f350
u joint or axle barrings
Old Jan 14, 2009 | 09:11 PM
EMD_DRIVER's Avatar
EMD_DRIVER
I figured it was a U-joint, but I checked all three of them. Tight as can be... Carrier bearing was the only thing with what I consider abnormal play in it.
Old Jan 14, 2009 | 09:14 PM
joe f350's Avatar
joe f350
that prolebly it there should be play in it
Old Jan 15, 2009 | 12:32 AM
Wookie35's Avatar
Wookie35
Could be tail shaft bearing or pinion bearing, carrier would be my last thought as it is made to flex some and unless severely deteriorated, should last for darn near ever. My 84 is still original and looks good so far. Good luck!
Old Jan 18, 2009 | 11:27 AM
ford trans tech's Avatar
ford trans tech
a u joint that is beginning to seize will cause this type of vibration
did you remove the driveshaft and check the u joints for stiffness
Old Jan 18, 2009 | 03:15 PM
EMD_DRIVER's Avatar
EMD_DRIVER
Trying to get the drive shaft off now... Someone decided to put red loctite on the torx head bolts that hold the u-joint to the axle yolk!
Old Jan 18, 2009 | 08:04 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Out comes the torch.
Time for some heat on the bolts.
Old Jan 18, 2009 | 08:07 PM
EMD_DRIVER's Avatar
EMD_DRIVER
Heat 'em up!
Old Jan 19, 2009 | 02:33 PM
Dave Sponaugle
After reading through this again, I don't think I would rule out the carrier bearing.
But then you have to get the driveshaft out before you can change it, so I guess first priority is driveshaft out and check the U joints.
