Cold start miss fire
Old Jul 2, 2021 | 09:13 PM
Ogre20012001's Avatar
Ogre20012001
I need help.
I have a 2005 v10 limited 4x4
i have a cold start miss fire on cylinder 4.
it only misses on cold start for about 2 - 3 minutes.
Then goes away and runs just fine.
when running errands it will start just fine no miss.
if the engine has time to fully cool off then it will miss on start up. For about 2 minutes then goes away.
Miss fire developed on cylinder 7 and 5. I ordered motorcraft plugs and denso coils. I did a tune up.
and now my cylinder 4 miss on startup is here.
code is random miss on start up and cylinder 4 miss.
I have moved coils around to see if miss would move with coil. Miss stays on cylinder 4.
gap on plug is set at .054 and torqued to 20lbft.
any suggestions will be appreciated
thank you.
Old Jul 2, 2021 | 10:43 PM
R&T Babich's Avatar
R&T Babich
Originally Posted by Ogre20012001
.... I did a tune up.
I have moved coils around to see if miss would move with coil. Miss stays on cylinder 4. ....
Misfires can also be caused by a clogged/sticky fuel injector or wiring that is degraded.
Not sure how to test for a sticky injector.
The #4 power for the injector and coil comes from splices that would probably cause issues on other cylinders on that bank, but there could
be a problem in the wires from the splices to the #4 connectors.
Do you get a good 12v at the injector/coil connectors?
A wiring issue on just #4 would more probably be in the coil/injector wire to the PCM.
Or the grounding chip in the PCM could be bad for #4.
Old Jul 6, 2021 | 07:13 AM
Ogre20012001
i will check into the wiring.
not sure on fuel injector testing.
thank you for the information
ajschwab2004
2004 - 2008 F150
Mar 26, 2018 04:20 PM
dwh039
6.2L V8
36
Apr 4, 2016 09:39 PM
yzman
Dec 11, 2013 07:55 PM
ejkoz
1997 - 2003 F150
Jan 26, 2010 05:26 PM
84-250
Jan 4, 2008 04:27 AM
