97 expedition cold start help
Old Dec 10, 2013 | 12:20 PM
yzman's Avatar
yzman
1997 expy 5.4 eddy bauer,,when it is cold in the morning and i first go out to start it,,it cranks up, runs for 5 seconds then dies,,it does this two or three times then wont fire, just cranks and cranks,,then after starting and stopping for about 15 minutes of cranking, it will fire up and run fine, does the same thing every cold morning. Above 33 degrees starts right up,,please help????
Old Dec 10, 2013 | 05:57 PM
alloro's Avatar
alloro
How many miles on the spark plugs?
Old Dec 11, 2013 | 12:32 PM
yzman's Avatar
yzman
about 20k on plugs. Now it is missing on a cylinder, pulled wire off coil packs on at a time, all made a change, weird, pulled each injector wire one at a time, one had no change. I will go through each plug tonight??
Old Dec 11, 2013 | 03:46 PM
alloro's Avatar
alloro
Then that injector might be your problem.
Old Dec 11, 2013 | 07:55 PM
Mark62's Avatar
Mark62
all tested ok...
Found your problem...hopefully there are no other problems.
Y? they tested good.
I agree with alloro
Whitey Ford
19
Dec 2, 2015 10:11 AM
Firefighter 1406
15
Dec 28, 2014 08:56 PM
screwy
Modular V8 (4.6L, 5.4L)
Nov 25, 2008 09:14 AM
tainja
Aug 9, 2003 10:23 PM
81
1997 - 2003 F150
Jan 3, 2003 06:40 AM
