Cylinder 5 Misfire on cold start between 1000-1100 RPM's - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Reload this Page > Cylinder 5 Misfire on cold start between 1000-1100 RPM's
Old 03-18-2018, 09:09 PM
ajschwab2004
ajschwab2004 is offline
ajschwab2004 is starting off with a positive reputation.
I have a 2005 F150 5.4 3v, It's been sitting all day today till about 2 hours ago. I started it up for the first time today and as the idle was coming down from about 1500 RPM's, at about 1000-1100 RPM's trouble code came on. When I plugged in my scanner it said "cylinder #5 misfire detected" I checked the live data from the code and it was detected at 1043 RPM's. There was a rough idle for like 10 secs as the RPM's were dropping from 1500. Anyway, I let it warm up some before putting it in drive and driving it, and it drove fine. Anyone know what could be the cause?
Old 03-18-2018, 10:07 PM
Ted928
Ted928 is offline
Ted928 is starting off with a positive reputation.
bad plug, poor plug seating, bad COP, ...
The best thing is to set up mode $6 monitoring so you can watch misfiring of all the plugs (prior to throwing a CEL).
This link may help https://www.ford-trucks.com/forums/1...-no-codes.html
Old 03-19-2018, 11:37 AM
pdqford
pdqford is offline
pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.
Or maybe you have an sticky fuel injector in #5. After it sets a while the injector may leak some fuel into #5 and when you go to start it, #5 may misfire until it clears out the excess fuel. Maybe.
Old 03-24-2018, 08:19 AM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
humidy / moisture on a cracked coil cable ?
Old 03-26-2018, 04:20 PM
ajschwab2004
Well, it's been a week or so today that the misfired happened and after so far it hasn't happened since. What I'm thinking is change the plugs back to motorcraft for all 8 cylinders, change the COP, and fuel injector for #5 and see if it comes back again in the future.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
