Trans slip
Old Jul 1, 2021 | 07:15 AM
69torino's Avatar
69torino
Trans slip
Hey everyone, I have been a member here for several years but hadn't posted in a long time and when I went to sign in I couldn't remember what email or password I had used previously, so back again under a new moniker. My 94 shortbox, 4.9 L has had a couple of hiccups the last two times I had it out with the worst being the other day when it actually slipped in first gear then a hard shift into second with an audible bang. Truck has 149 ooo km, 80000 miles, fluid is bright red and level fine on dipstick. Truck has always been a toy, I have had it 8 years , never winter driven. Fluid was changed at 104 km, 8 years ago. I figure I am likely looking at a rebuild, wondering if flush and adding Lucas trans fix might make last thru the summer ? Any opinions appreciated. Thanks.
Old Jul 1, 2021 | 10:36 AM
Conanski's Avatar
Conanski
Your trans is computer controlled so you should start with pulling codes.
Old Jul 1, 2021 | 06:10 PM
69torino's Avatar
69torino
thanks for the reply. So any code reader will also cover a trans issue and I don't need to go to a trans shop specifically ?
Old Jul 1, 2021 | 07:59 PM
Conanski's Avatar
Conanski
Both engine and trans are controlled by the same computer, that means there is only one place to get codes but it also means any sensor issue on the motor or trans can affect operation of either component, so you're not just looking for trans related codes. You will need an OBD1 Ford specific code reader too not some generic thing, the one to get is the Equus/Innova 3145.
Old Jul 1, 2021 | 09:00 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Here is another way to read the codes: www.troublecodes.net/ford
Old Jul 2, 2021 | 06:28 AM
69torino's Avatar
69torino
thanks guys. My check engine light has been on for years lol. my mechanic always says it is a bad o2 sensor , the light stayed on after replacing the sensor so he said don't worry about it. I only put about 500 miles a year on the truck now with covid and my other vehicles , I will book it in for a scan and see what codes come up.
Old Jul 2, 2021 | 11:06 AM
My4Fordtrucks's Avatar
My4Fordtrucks
What kind of “mechanic” tells you not to worry about the check engine light being on? He didn’t clear the code(s) after replacing the oxygen sensor?
Old Jul 2, 2021 | 05:21 PM
AuroraGirl's Avatar
AuroraGirl
maybe he wants his lack of fixing a problem to be worried or investigated if the guy believes him to not worrry
Old Jul 3, 2021 | 11:31 AM
69torino's Avatar
69torino
the code was cleared ,the light comes back on, it is always the O2 sensor code, it has been replaced. I haven;t had it checked for a few years as my truck is not used regularly. I have it booked for next Thursday. If I'm told I need a new computer, is there an option to buy one new, or one already rebuilt or flashed ? I haven't checked with the local Ford dealer parts counter yet, but the last time I was looking for a part, [ wiper switch ] , they said they don't have anything for OBS anymore.
Old Jul 3, 2021 | 11:48 AM
My4Fordtrucks
Not sure why you would make an appointment to have codes read. As was stated in posts 4 & 5 you could buy a $25 code reader or use a paper clip and get them yourself. I hope they aren’t charging you a diagnostic fee to pull the codes.
You can buy Motorcraft parts online so jo need to visit the dealer for them. According to one of the members here the PCM/ECM that Ford has is the same are manufactured Cardone unit you’d get anywhere else.
Old Jul 3, 2021 | 11:56 AM
69torino's Avatar
69torino
thanks for the reply. I won't be charged to have the scan done. I have been going to the same guy for over 20 years. He is a Ford man, owns a 96 F350 . I have a disability in my hands and cannot hold onto anything with precision for more than a few seconds . you should see how long it takes me to type a message on here lol. Is Cardone a reman type business ? I'm on Ontario Canada. I'm not familiar with that brand . I will likely just let my tech find the parts necessary , just curious at this point.
Backwoods351
35
Aug 30, 2014 05:13 PM
RhinoScores
1978 - 1996 Big Bronco
Dec 26, 2013 08:19 AM
BiggDogg77
Jan 30, 2013 07:01 AM
robjs111
1997 - 2003 F150
Nov 16, 2009 04:53 PM
WorkVan58
Aug 4, 2008 07:28 AM
