power steering issue
Old Jul 1, 2021 | 02:52 AM
pinehillian's Avatar
pinehillian
hey all. here is another p/s problem, lookin forward to hearing what yall think. 79 f150 on 78 4x4 frame w/351m, after sitting 18 years (starting and moving couple times a year) getting ready for the road after long and needed restoration. runs great but no p/s, installed new pump and lines this week but only replaced what fluid lost during install, some say flush some dont but either way no new p/s. jacked up and lock to lock many time still nothing. (not running then running) after doing that in pump is real foamy, with cap off fluid goes up an down im assuming thats normal? yrs ago probly had some trans fluid in system. had to use old cap- doesnt seem air tight, my question is lock to lock not running cap on or off and when running lock to lock cap on-off? #2 does it need a flush and best way to do it? #3 bleed or not or not to bleed, i already read many post and seems to be mixed coments but open to all suggestions or i may be missing something obviuos, thanx in advance pine
Old Jul 1, 2021 | 07:55 AM
headloct's Avatar
headloct
I would guess that the pressure relief valve in the new pump is stuck open.
Old Jul 1, 2021 | 09:44 AM
pinehillian
hey HL, do you think that because foaming, level goes up and down or pump not working? how would i tell or check it
Old Jul 1, 2021 | 07:57 PM
mark a.'s Avatar
mark a.
There is air in it or getting in it.
Old Jul 2, 2021 | 02:29 PM
pinehillian
i agree but how do you get the air out?
Old Jul 3, 2021 | 10:19 PM
hivoltj's Avatar
hivoltj
Jack up the front end and turn lock to lock over and over until there are no more bubbles in the reservoir. Then start it and do the same
Old Jul 6, 2021 | 07:24 AM
pinehillian
mornin, hey i got pump actually working, many turns and flushing, for a new pump its whining pretty bad (almost as bad as me) i figured maybe try some p/s additive, any thoughts?
Old Jul 6, 2021 | 08:14 AM
460me's Avatar
460me
I just when through this. Sand the pulleys and get them nice and shiny and new belts. No more squeal and racket.
Old Jul 6, 2021 | 10:57 AM
pinehillian
i can try that but its not a belt squeeling as to more whining sound from pump, the sound like it is low on fluid. im going to flush a few more times and see if it does anything. theres old fluid in system that im trying to remove. i add new then run it then get my old turkey baster and remove mixed fluid, add more and again, gettin better but still whining
Old Jul 7, 2021 | 10:23 AM
mark a.'s Avatar
mark a.
If your sure it isn't leaking anywhere ? I would get a Mityvac hand vacuum pump with their adapter for pumps and vacuum in down.
Old Jul 7, 2021 | 12:14 PM
redroad's Avatar
redroad
Have you checked out this thread ?
and this one ?
Old Jul 7, 2021 | 02:06 PM
pinehillian
hey red, thats some good readin there, thanx, also many many yrs ago you sent me a drawing of timing marks and specs, thanx and to all others willing to help,
Old Jul 7, 2021 | 02:27 PM
redroad's Avatar
redroad
No problem, you're welcome.
gittinwidit
Jan 30, 2018 09:47 PM
Swamp Truck
Dec 31, 2017 05:27 PM
kegger66
15
May 30, 2016 06:44 PM
moneypit79
Jan 7, 2008 06:59 AM
sb1234_99
1978 - 1996 Big Bronco
Jul 25, 2007 11:13 AM
