I soaked the cylinders with penetrating fluid and still cannot get the engine to turn over with an breaker bar.
You might try taking a piece of 4X4, might have to shave the corners off, or something similar like a piece of post of the appropriate length and put it in the rusty cylinder and hit it with a sledge hammer to try and jar the piston loose.
This exactly. I bought a '95, 351, Ext. Cab, 4wd in 2015 that the engine was seized. I removed the heads, soaked the cylinders. Nothing! I used a race jack with a 3 ft. steel bar, 1/2" thick, bolted to the harmonic balancer, pushing the engine in the opposite direction. Nothing! Bought a 8ft, 2x2, cut it in half, and used it to pound each piston in the opposite direction and it finally broke loose. The engine had been hydrolocked and every cylinder was pitted, rusted. Each piston had seized to the cylinder walls.
