putting a 5.0 & Aode4 trans together
I have never had this much trouble putting a transmission & engine together. The engine is an ATK rebuilt should be a 82-85 mustang part # DF11, the transmission is from a junk yard should be from a 95 F150 4 speed automatic electric, The flex plate is from an old 89 bronco 5.0 I had. I put the flex plate on to the converter ok and the converter goes into the tranny ok. when I try to put it all together either the top or bottom of the tranny will not go in. I even took it apart twice the 2nd time I used 4" studs into the engine and slid everything together and same thing
Any ideas before I give up and go get a C-4
Is there a pilot bushing in the end of the crank for the Mustang's 5 speed? Are you sure you have the converter drain plug going into a hole in the flexplate? Is the converter set into the pump all the way back? Those are the 3 most common reasons why people have trans to block fitting issues.
nissen4
12-15-2016 08:53 AM
rudedogii
13
03-16-2012 01:26 PM
JAYS69F100
17
05-05-2008 09:08 AM
