E40D Converter Screw Up, Help!
Old Mar 13, 2012 | 12:23 AM
rudedogii's Avatar
rudedogii
Got my E40D trans back on the Bronco but I dont think I installed the torque converter right. What do I do know?
How much will a shop charge to fix?
Should I even start the motor?
I think I'm screwd!
Old Mar 13, 2012 | 09:30 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
DO NOT START THE ENGINE!!!!!!!!!!!!!!!!!!
If it isn't fully seated and you pulled the trans all the way to the engine you have damaged the end of the torque converter and probably yhe pump, too. Starting the engine will just do additional damage. You might have to replace the torque converter and pump, sometimes they can be repaired if the engine hasn't been run like this.
Old Mar 13, 2012 | 11:06 AM
rudedogii's Avatar
rudedogii
Thanks
I figured something like that. No I havent started the engine. I just got it all back together and havent yet filled the trans with fluid.
What should I do now?
Old Mar 13, 2012 | 12:00 PM
Mark Kovalsky
Can you turn the engine over using a wrench on the crank pulley? If it turns freely you have it assembled right. If it is bound up the next step is to take the trans out and see what's damaged.
Old Mar 14, 2012 | 08:02 PM
rudedogii's Avatar
rudedogii
Hand crank?
Yes I was able to hand cranked the engine to tighten the converter bolts. So I hope thats a good sign?
I will be back at it saturday. I need to clear my head and think this out.
First thing I am going to check is the lever that controls the park brake. Maybe it's not engaging so the trans is staying in park. I hope thats all?
Next I'm going to pull the transfercase and see if that truns free.
Last thing is to remove the trans!
Old Mar 14, 2012 | 09:17 PM
Mark Kovalsky
I don't understand how we moved from the torque converter to park or to the transfer case.
What problem are you trying to fix here?
Old Mar 14, 2012 | 09:34 PM
rudedogii's Avatar
rudedogii
I'm sorry! I was cleaning up and wanted to clean up under the truck. So since I havent started the motor or filled the trans with fluid I tried to roll it backwards. It would only roll about a foot! Why? I hope thats not a bad sign.
Old Mar 15, 2012 | 04:14 PM
Mark Kovalsky
Even if the torque converter isn't seated and has the engine jammed solid the truck will still roll just fine. Your problem is not the torque converter. You've done something wrong with the linkage or have something wrong in the transfer case.
Old Mar 15, 2012 | 05:46 PM
rudedogii's Avatar
rudedogii
Video
I made a video explaning my trans stituation. I hope this gives you a better idea of what could be the problem.
I plan on checking the trasfercase next. I really appreciate the help!
******** style="height: 390px; width: 640px"><param name="movie" value="http://www.youtube.com/v/xwrdhos8IvQ?version=3&feature=player_detailpage">< param name="allowFullScreen" value="true"><param name="allowScriptAccess" value="always"><embed src="http://www.youtube.com/v/xwrdhos8IvQ?version=3&feature=player_detailpage" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="640" height="360">*********>
Old Mar 15, 2012 | 08:33 PM
rudedogii's Avatar
rudedogii
Transfercase OK
Split the transfercase and moved the forks around in and out of gear and still can not turn the shaft backwards. So I think the transfercase is ok.
So next thing to do is pull the trans one more time and tear it back down.
Could I have installed the "one way clutch assembly" in the "Intermediate Brake Drum" backwards? Is this possible?
Old Mar 16, 2012 | 10:25 AM
Mark Kovalsky
Yes, it's possible. I've known it to happen. Just never to me. ;-)
Old Mar 16, 2012 | 11:32 AM
rudedogii's Avatar
rudedogii
Thats where I'm gonna look.
I was looking over the ATSG repair manual and saw the "NOTE" about installing the one-way clutch assembly turning counterclock wise.
Is there anything else I should look for?
Old Mar 16, 2012 | 12:56 PM
Mark Kovalsky
I just watched the video. It's the one way clutch in backwards. The torque converter and pump have nothing to do with this problem. Either does the transfer case. It's the one way clutch installed backwards.
If you can spin the engine with that small ratchet either you are amazingly strong or you have the torque converter and pump installed correctly.
Old Mar 16, 2012 | 01:26 PM
rudedogii's Avatar
rudedogii
Thanks!
Thanks again Mark. I just picked up the trans jack from the rental yard. I will be spending the rest of the day pulling out the trans again! I got to hurry, its gonna rain!
Marmst23
Jun 8, 2019 07:49 AM
1989Ford7.3L
Dec 29, 2009 09:30 PM
scatterbrained
Dec 3, 2009 11:48 AM
btorear
Jan 1, 2009 08:38 PM
Dmax Stroked 00
21
Oct 21, 2008 02:56 PM
