Sponsored by: Real Truck
Front receiver installation issues
Old Jun 29, 2021 | 06:04 PM
pizzle's Avatar
pizzle
Hey guys, I'm trying to install the Curt 31114 front hitch and the holes don't line up frame rails. Is my truck a total bent-dick?
Info: F-250 2000 PSD, 2WD, 6sp
Old Jun 29, 2021 | 06:22 PM
Just Strokin's Avatar
Just Strokin
nope, just make the holes slightly lager
Old Jun 29, 2021 | 08:22 PM
SuperDutyScaler's Avatar
SuperDutyScaler
I've installed two of these curt hitches on the 99-04 super duty trucks. Holes lines up both times...
Old Jun 29, 2021 | 09:22 PM
nydiver's Avatar
nydiver
Put a ratchet strap from one tow hook to the other and see if you can pull the horn just a bit to the passenger side to get those bolts in. opening the holes up would be a last resort
Old Jun 30, 2021 | 11:07 AM
pizzle's Avatar
pizzle
Which? On the frame? I don't think I have anything with enough juice to bore out the hitch -- that thing is thick.
That's a really good idea I'll give it a shot. Just never thought I could bend the frame that much with just simple tools.
Old Jun 30, 2021 | 11:24 AM
nydiver's Avatar
nydiver
Get one of those 2" wide over the road ratchets from tractor supply, the handle is much longer and stronger, you'll get some good leverage. You only have to move it, what? 1/4"?
Old Jun 30, 2021 | 12:00 PM
williamg4x4's Avatar
williamg4x4
even a cable come along with a long handle probably move that very easily.
Old Jun 30, 2021 | 06:12 PM
countrydr's Avatar
countrydr
Before final attachment of the hitch - I'd recommend chelating the rust on the frame and then shooting it with a few coats of paint. Rust prevention is worth a pound of iron oxide dust.
Old Jul 1, 2021 | 04:50 PM
JackOHearts's Avatar
JackOHearts
Thumbs up
Good luck. Hope you get it attached.
I went w the Reese 65049.
Looks like they mount differently.
Looking forward to using it for a bike rack..
Old Jul 1, 2021 | 06:13 PM
David_h's Avatar
David_h
I would do the ratchet strap. My 2008 frame horns needed to be spread out slightly after I made my custom front receiver. I wish i could have used a ratchet strap but needed to use a home made spreader to force them apart. They are not that hard to move.
Old Jul 2, 2021 | 01:07 PM
lshort's Avatar
lshort
large tapered punch, drive it in until bolts will go in.
Old Jul 2, 2021 | 01:52 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Make sure that any bolt on either side remains LOOSE untightened, until ALL bolts are inserted.
If one side is tightened first, then that would undermine the tolerances provided by the slotted holes in the hitch flange and frame horn.
PE1948
Jan 8, 2020 09:02 AM
annaleigh
Dec 8, 2019 08:46 AM
351Cleveland C4
33
Nov 25, 2017 10:52 AM
stimm32
Sep 6, 2013 12:25 PM
blue95f250460
Jan 26, 2013 07:21 PM
