FLIR Thermal Image Camera Installed
Old Jun 23, 2021 | 08:13 PM
smikesF350's Avatar
smikesF350
Originally Posted by Peakebrook
Did you try using the FLIR mount before you fabricated your own mount?
Not the mount they specifically sell for it, which is just a ball "RAM" ball style mount. Two problems present with that style; lack of stable surface to screw the base of the mount to behind the grill and second, those mounts may work ok with a vehicle that has really soft cushy suspension, but our truck don't. I use those style mount when I installed Motorola Remote Radio Heads. Just not really a stable platform IMO. With the mount I fabricated, once it is aligned and locked down with the bolts, the camera is not going to change its alignment. As, a side note, I definitely wanted the protection that a behind the grill install inherently provides protection against theft and rock/debris hits. The space behind the grill is tight, but with the camera's narrow field of view of 24 degrees, mounting the camera with a slight rearward offset really "hides" the camera.
Old Jun 23, 2021 | 08:35 PM
smikesF350's Avatar
smikesF350
Originally Posted by Phoenixfla
This is a great thread and I appreciate you taking the time to write it up. Maybe if it gets wider adoption the price will come down. Sure would be great with a heads up display.
I also have to think this will be part of the safety array in future autonomous vehicles.
Thank you. If anyone is contemplating a similar project, I'd be happy to share tips or tricks that originally took me some time to figure out. Several models of the "high end" luxury cars- like Cadillac currently use this technology. Maybe not the FLIR product but some adaptation of it. For me FLIR is the industry leader so there is peace of mind with that. I did have to sign a document that I was not going to mount the camera a missile.
This was how I did a rough mount mock-ups and alignments. It worked great as I only had to adjust the horizontal or left/right about 2 degrees to the right for final alignment. The cardboard represents max distance to the cooling coils. The surrounding mess represents several other projects- re-build a backhoe loader, rebuild my sandrail motor and trying to fully move out of calif.
Old Jun 23, 2021 | 08:41 PM
smikesF350's Avatar
smikesF350
Originally Posted by SARDiverDan
wonder how it works in heavy/whiteout snow conditions when you are trying to get down the highway and people are stopped in front of you on the road.
Not that well. Thermal imagery is based on temperature difference and a reasonable clear view. I encountered heavy mist kicked up by big rig truck and light rain and the system was not "seeing" the heat front the truck tires and brakes.
Old Jun 23, 2021 | 08:48 PM
smikesF350's Avatar
smikesF350
Originally Posted by GNR22
That does look pretty slick. I can certainly see the benefit for spotting deer at night. I think I'd find it to be a distraction, with all the other screens in the truck.
Really, once the "wow" factor diminished it was not distracting. The NAV-TV FLIR-XW interface gives a tone when it detects a potential target. There is also a yellow lined box imposed around the possible threat.
Old Jun 23, 2021 | 09:01 PM
ssoundwave's Avatar
ssoundwave
i was looking at this before and remember it dosnt like cold temps! also it would get covered in snow fast!
Old Jun 23, 2021 | 10:17 PM
SARDiverDan's Avatar
SARDiverDan
I have a few FLIR products and used them both in the military and LE. I know various fire departments have FLIR units that work well in no visibility/smoke filled areas. Just wondering if the higher tech has trickled down to these smaller units yet.
Old Jun 24, 2021 | 04:56 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
The only thing I'm seeing is that beautiful '86-'87 250R
Nice work on the "investment" as you call it! I can see where it could come in handy!
Old Jun 24, 2021 | 09:14 AM
H4Racing's Avatar
H4Racing
Nice TRX250R in the background.......
Old Jun 24, 2021 | 12:11 PM
Rock_Lobster's Avatar
Rock_Lobster
Trailering
........ and trying to fully move out of calif.
Get your priorities straight. Drop the other projects and get out of kalifornia . I did after 51 years and its the best thing I ever did.
Old Jun 24, 2021 | 12:16 PM
smikesF350's Avatar
smikesF350
Oh yea, the grand Socialistic Republic of California!!
Old Jun 24, 2021 | 07:37 PM
smikesF350's Avatar
smikesF350
[QUOTE=ATC Crazy;19941437]The only thing I'm seeing is that beautiful '86-'87 250R
Good eyes. It is in fact a 1986 Honda TRX 250R. Still running strong and all factory OEM. Still have a 1985 Honda 200X ATC three wheeler.
Old Jun 25, 2021 | 08:18 PM
smikesF350's Avatar
smikesF350
Forgot to include the photograph of my dash. This was the only modification to my truck- it was painful to drill a hole in the trim for the combo alert indicator light / mute button.
Old Jun 26, 2021 | 12:52 PM
  #28
ssoundwave's Avatar
ssoundwave
i dont think i could settle with that button, I would be online looking for something that matches the truck, but thats just me
Old Jun 27, 2021 | 09:02 AM
  #29
smikesF350's Avatar
smikesF350
Your right. That's a good point. Have to admit that did not occur to me since it was pre-wired. It is just a momentary illuminated switch.
maypo59
Feb 23, 2018 07:47 AM
VoLc0m St0n3d
2009 - 2014 F150
Mar 15, 2017 10:52 AM
Tredeh
1997 - 2003 F150
Oct 12, 2015 05:06 PM
jade97
2009 - 2014 F150
18
May 20, 2011 01:38 PM
1999XLT
Dec 10, 2003 12:46 PM
