This doesn't look right
Old Jun 20, 2021 | 07:19 PM
turnrjr's Avatar
turnrjr
Installed the speedometer cable today. It's a new cable from Mid-fifty and my stock 3 speed transmission has a R10 overdrive. I don't remember what it looked like 10+ years ago when I tore down the truck for restoration. It seems to me that the flange on the cable end should bottom out against the case. I tried it with and without the speedo gear installed. The O-ring does make contact for a seal. Also it seams that the clamp is on the cable backward.
Is this installed correctly?
Thank you
Bob
Old Jun 20, 2021 | 07:30 PM
EBEAR's Avatar
EBEAR
The clamp appears to on backwards and the speedo cable housing should push right in so the o ring is not visible . Vaseline works well to slip the o ring in .
Old Jun 20, 2021 | 08:40 PM
56panelford's Avatar
56panelford
Is the cable inserted as far as it can go, doesn't look like it is fully seated..pretty sure the clamp is in the right direction ..
Old Jun 21, 2021 | 05:41 AM
turnrjr's Avatar
turnrjr
I'll try again with some Vaseline. At first I thought maybe the speedo gear wasn't mated to the drive gear so it kept the cable housing from going in. When I tried it without the speedo gear it was the same. The clamp is placed over the cable during manufacture and can't be flipped.
I appreciate the help.
Old Jun 25, 2021 | 07:15 AM
turnrjr's Avatar
turnrjr
Got it seated properly. Not sure what the issue was but I did lube the o-ring and rotated a bit.
Old Jun 25, 2021 | 07:22 AM
EBEAR's Avatar
EBEAR
Excellent . Much easier to ask than break things like me . lol
diggerrigger
Jun 3, 2024 02:02 PM
Sparty73
Nov 20, 2019 09:07 PM
91Fbody
Feb 28, 2016 07:31 AM
TampaDave
Large Truck
Jun 8, 2015 12:51 PM
62 squire
Feb 5, 2013 12:38 PM
