Headlight low beam n/w
Old Jun 19, 2021 | 04:02 PM
2018f250stx's Avatar
2018f250stx
My passenger side upper low beam is out , replaced bulb still does the same thing no low only high beam. Checked wiring I don't see any damage. Look in manual nothing listened for fuses for headlights . Anyone have a wiring diagram? I can't find one online.
Old Jun 19, 2021 | 05:12 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Have you checked voltage with a DVOM?
And, it's not unheard of to get a new bulb that is bad.
Old Jun 19, 2021 | 05:16 PM
jimzpsd's Avatar
jimzpsd
Check for a bad ground connection, from the socket ground wire to the chassis. And while your at the socket, confirm it does not have power on the low beam circuit, if it does then you have a bad bulb.
Old Jun 19, 2021 | 05:26 PM
ford390gashog's Avatar
ford390gashog
Are you receiving a bulb outage message? Have you made any forscan changes?
Old Jun 19, 2021 | 06:17 PM
h20camper's Avatar
h20camper
Bad ground would affect both hi and low beam as the bulb shares the same ground for hi/low.
Old Jun 19, 2021 | 06:22 PM
h20camper's Avatar
h20camper
Here ya go....
Old Jun 19, 2021 | 07:30 PM
2018f250stx
Originally Posted by h20camper
Here ya go....
thanks , ill have to find a few hours to start tracing it, I was hoping it was going to be a fuse but that's not the case
Old Jun 19, 2021 | 07:34 PM
2018f250stx
the high beam is working it uses the same ground as the low beam,,, I did try other bulbs
Old Jun 19, 2021 | 08:10 PM
jimzpsd's Avatar
jimzpsd
Your right,............thank you for the correction
Old Jun 20, 2021 | 06:32 AM
2018f250stx
I've got a bad feeling it's the bcm, hope it's covered under warranty
Old Jun 26, 2021 | 09:45 PM
2018f250stx
Found it, Dang chipmunk chewed the wire
mechasus
Escape & Escape Hybrid
Oct 25, 2021 04:06 PM
thepatriot76
21
Jul 26, 2006 08:41 AM
lon371
1997 - 2003 F150
Jan 30, 2005 11:21 AM
lwardell
Electrical Systems/Wiring
Dec 3, 2004 03:36 PM
joners
Feb 5, 2004 10:28 AM
