Hey all,
Currently on vacation with the family, my 2001 EX, and our Keystone Bullet. Outside Terre Haute IN on our way to Columbus OH I hit a massive bump in the road and the ABS light immediately came on. We just now pulled off in Terre Haute for a Culver's burger. Crawled under the rig and found the wiring to the plug that clips in to the ABS sensor is frayed clean thru, and right at the plug so I can't splice it back together. Picture below. Anyone know if I can get that plug and if so what the part number is? I'm sure I can hit up a parts store once we get to Columbus and splice in a new plug. Any other tips would also be appreciated.
if you cannot find that plug, at the auto store, you can always disconnect that plug from the sensor, and use some quick slide terminals on the wires/circuits and direct connect to the pins of the sensor (just remember which color wire goes to which pin). get some di-electric grease and pack it in there to protect it, cover with electrical tape and zip tie the pigtail in place to the sensor to keep it from pulling out. that should work until u can get the service pigtail
Thanks again for the PN @Dweber85rc -- I got into Columbus tonight and the local Napa will have both the plug and the sensor available for pickup on Monday. Figure as long as I'm splicing in a new plug I should replace the sensor too.
