Sponsored by: Real Truck
Abs Sensor wiring
Old Jun 20, 2020 | 09:51 AM
cat633's Avatar
cat633
Abs Sensor wiring
I have a 2000 F250 with the 7.3 and my wife blew the left front tire a while back which pulled the Abs senor plug apart. I can't find where to plug it back in is my problem. I have looked behind the fender well like I have been seeing on where the plug should be but it's not there so I'm trying to find where the other end of that plug would be so I can trace it down and plug it back in.
Old Jun 21, 2020 | 10:17 PM
DaveP.'s Avatar
DaveP.
Can you look at the Right Side and get an idea of location and the routing? Probably not a lot different.
Old Jun 24, 2020 | 07:19 PM
cat633's Avatar
cat633
I tried following the right side but i lose it when it gets above the fender well. So now I have my air box and battery box pulled out so I can see the abs module and still can't find the plug. I've traced every wire loom coming out of the module and still nothing.
Old Jun 24, 2020 | 09:08 PM
cat633's Avatar
cat633
Ok I pulled the left fender well down and found the 2 wires that used to go to the plug on the truck side. Now my question is can I cut the plug off the sensor side and hard wire them together?
Old Jun 25, 2020 | 11:08 AM
redrivergorge's Avatar
redrivergorge
Yes you can, use crimp connectors and heat shrink. Ideally you'll go to the junkyard and cut a harness out of a truck and splice that in so the abs sensor replacement is easier later.
Old Jun 25, 2020 | 02:29 PM
cat633's Avatar
cat633
Thanks, I actually just left NAPA and they were able to order me the connector with a pig tail for $15 so I went that route.
Angrywasp
Sep 12, 2017 08:03 PM
mariolachaine
Aug 21, 2017 07:24 PM
jrbpit1
May 20, 2011 12:22 PM
96Broncowner
1978 - 1996 Big Bronco
Aug 18, 2005 08:35 AM
