Trailer TPMS/Camera installation
For anyone looking t get someone to do this, if youre in the area, Sundowner know what theyre doing, walked through camera placement, TPMS sensor placement, even where to put the storage port for the 12pin..
Anyone else had one of these installed on their trailer?
https://www.ford-trucks.com/forums/1...sor-kit-2.html
Originally Posted by MagicMtnDan View Post
Here's what I posted in this thread (https://www.ford-trucks.com/forums/1...-2021-a.html):
I finally got my Ford Aux Camera and TPMS kit and, from my experience:
* Ford promotes Super Duty towing but IMO, does a ****-poor job of providing information about the options they sell including differences between the kits, what comes with them and any info about installation
* Ford parts people and dealership people have little to no useful information about these kits
I had to walk my parts guy through the options referring him to Ford websites which are woefully inadequate. He told me it would come with the Yaw Sensor which I came with my F350 which has the UTT package. I knew it didn't but wouldn't have complained if it did. Of course he was wrong.
FYI: This weekend I read through the photocopied lousy instructions from Ford that came with the kit and found out that I'd have to replace the bumper mounted plug unit (1 plug unit has both trailer plugs in it) with the one supplied in the kit. It would have been good to know this and know that the kit replaces that plug's flat 5 pin trailer connector with the Camera Plug connector (in the lower position). And the kit comes with a 7-pin-to-5-pin adapter should you need to plug in a trailer with a flat, 5-pin plug.
By the way, if you have the Yaw Sensor and actually want to use it for the "Pro Trailer Backup Assist", you'll have 3 cables connected: (1) trailer lighting, (2) Yaw Sensor cable for Pro Trailer Backup Assist (those 2 go into the plugs inside the bed), and (3) the Camera cable that plugs into the new replacement plug in the bumper). <-- This is incorrect (see below for correct info)
Here's a pic from https://www.levittownfordparts.com/s...8aAlLREALw_wcB (note this link is for -E version) that shows what's in the kit. Last 3 items in the lowest row are, in order: the adapter, the replacement bumper plug and the TPMS sensor.
Here's some links:
https://accessories.ford.com/kit-tpm...1/Super%20Duty
https://www.ford.com/trucks/super-duty/features/smart/
https://www.fordservicecontent.com/F...-US_8_2020.pdf
This is about as much info as I could find on Ford towing - 46 pages
https://www.fleet.ford.com/content/d...owingGuide.pdf
This screen capture is from page 45 (forget about the parts guy knowing the differences between -A through -F):
Owners Manual (for those who aren't yet owners interested in learning about this stuff) links:
Pro Trailer Backup Assist:
https://www.fordservicecontent.com/F...userMarket=USA
Integrated Ford Brake Controller:
Trailer Tire Pressure Monitoring System:
Diesel Engine Exhaust Brake (not easy to find info on this from Ford) - this is what I've found so far:
https://www.ford.com/trucks/super-du...l-engine-only-
This is better than FoMoCo's info: https://www.sherwoodford.ca/blog/6-7...ust-braking/#/
From the manual: https://www.fordservicecontent.com/F...userMarket=USA
Of course this place is more helpful than Ford: https://www.ford-trucks.com/forums/1...-settings.html
