Exhaust brake use/settings - Ford Truck Enthusiasts Forums
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
View Poll Results: Engine Brake Usage
I never use it 1 1.79%
I use it when i feel i need it 28 50.00%
I use it 50% of the time 10 17.86%
I use it all the time 7 12.50%
I use the Regular setting (one tap) 21 37.50%
I use the Automatic setting (two taps) 19 33.93%
Multiple Choice Poll. Voters: 56. You may not vote on this poll
Old 01-18-2018, 11:28 PM
diamondbackmike2004's Avatar
diamondbackmike2004 diamondbackmike2004 is offline
diamondbackmike2004 is starting off with a positive reputation.
The exhaust brake has came up a few times and i was curious who uses it regularly and what setting do you use it in?
Option 1: I Dont use it ever
Option 2: I Use it when i feel I need it
Option 3: I Use it 50% of the time
Option 4: I Always use it
Option 5: I use the regular setting (one tap)
Option 6: I use the Automatic setting (two taps)
Old 01-19-2018, 06:54 AM
wrvond's Avatar
wrvond wrvond is offline
wrvond has a good reputation on FTE.wrvond has a good reputation on FTE.wrvond has a good reputation on FTE.
I have been using it in the mountains when pulling a camper.
Old 01-19-2018, 08:24 AM
BowtieConvert BowtieConvert is offline
BowtieConvert is starting off with a positive reputation.
I use it when towing. As flat as it is around here I could probably get away without it but it's nice rolling to a stop and listening to it doing its job.
Old 01-19-2018, 08:59 AM
ncsuperduty's Avatar
ncsuperduty ncsuperduty is offline
ncsuperduty is starting off with a positive reputation.
i use it all the time whether i am towing or not. i am hoping it helps prolong brake pad life. i use the manual setting, unless i am on a freeway going down a mountain then i use the automatic. seems to be working really well.
Old 01-19-2018, 09:09 AM
H4Racing H4Racing is offline
H4Racing is starting off with a positive reputation.
I use manual mode while towing, sometimes if I am in traffic I'll use it as well.
Old 01-19-2018, 09:26 AM
backtrack2015's Avatar
backtrack2015 backtrack2015 is offline
backtrack2015 is gaining momentum as a positive member of FTE.backtrack2015 is gaining momentum as a positive member of FTE.
I use it when towing and only occasionally use it otherwise. I use manual mode with downshifts if slowing down and automatic mode if trying to maintain a set speed on a descent.
I wish we had two dash buttons so I could hit either mode with one button press. I also wish it didn’t “chime” because I like to keep things quiet and let people sleep.
Old 01-19-2018, 10:08 AM
Super-Truck Super-Truck is offline
Super-Truck is gaining momentum as a positive member of FTE.Super-Truck is gaining momentum as a positive member of FTE.
I wouldn't be able to drive on the highway without it, makes lane changing and adjusting in high speed traffic much easier than braking. I have ran my exhaust brake 24/7 on all my trucks and continuing that trend with my 17. However all of those trucks have been RAMs
Unfortunatley the RAM exhaust brake is much better than ours on the 6.7 PSD. As soon as you let off the throttle in the RAM, the brake kicks in. In our super duties, it takes way too long for the brake to kick in. But the super duty brake does work really well once the tc locks and it fully engages.
Old 01-19-2018, 12:10 PM
17SD250Power 17SD250Power is offline
17SD250Power is starting off with a positive reputation.
I use it when towing the travel trailer - like a few folks here. Makes rolling to a stop an absolute dream. I was able to back off on the trailer brake as a result.
_____________________
Current: 2017 Magnetic F-250 CC Super Duty Lariat 6.7L
Exhaust brake brickman Fifth Wheel & Gooseneck RV Towing 12 01-02-2018 07:39 PM
# of blinks with lane change Flyct 2017+ Super Duty 17 12-18-2017 01:12 PM
Use of courtesy time out Adventure Rider 6.7L Power Stroke Diesel 272 09-04-2017 11:22 PM
Does anyone here install utility beds? Lubbockguy1979 1999 to 2016 Super Duty 11 02-20-2017 09:23 AM
Power windows and locks 2014 STX MikeF-150 2009 - 2014 F150 0 01-22-2017 12:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
