Hi folks, this is my first post in the Escape forum here.
I have a 2008 LTD V6 Escape.
The AC is blowing warm air. It worked fine last year, but since I've tried running it this summer it doesn't work at all. I picked up a recharge canister to see if it was low on fluid. When I attached the nozzle with the car/AC on high, to the low pressure nozzle, the gauge on the cannister didn't get a reading at all, like it was bone dry. That seemed weird, but I thought maybe there was a leak so I'd try filling it. So I start pulling the trigger to add fluid, and immediately I start hearing a cycling sucking noise followed by a click. I let off the cannister trigger to check the level, and the needle is bouncing up halfway into the full/green area, and then falling back down to empty, along with the sucking/clicking cycle. I left it alone for a minute and it didn't stabilize, just keeps building pressure, clicking, then starting over. I got underneath the car and the clicking noise sounds like it's coming from the compressor.
Need to find and repair the leak so you don't waste refrigerant.
With just a little bit of "juice" in there, it's completely normal to see a clutch cycle every few seconds. Each time it comes on, the pressure will drop. If it cycles off, the pressure will rise. If you have the valve to the can open, the pressure in the can will be enough to trip the low pressure cycling switch.
The thing that's confusing me, is after pumping fluid in for maybe 5 seconds, it went from totally empty to full. Since the needle wasn't stabilizing, I thought maybe it's not as full as it says, so I pumped more in for a few more seconds, and it's almost into the red range.
My mistake, I was reading the refill instructions wrong. I see I'm supposed to get a reading off the gauge at it's lowest level if it's fluctuating.
So I kept filling it, and got the refrigerant level up into the full range, and the AC started working in the car. I started to get some steam/smoke coming out of the grill towards the passenger headlight. I can see a green fluid leaking out where one of the AC lines plugs into something behind the grill. Does the AC connect to the radiator? Is that radiator fluid, or is the refrigerant green too?
Sounds like a fairly large leak. If that's the case not only is there no refrigerant in the system but you may also be low on refrigerant oil and the system is probably full of air. You need to fix the leak then get a vacuum pump on the system and see if it will hold a vacuum. Pulling a vacuum will also cause any moisture that got into the system to boil out. Then you can recharge with refrigerant.
You will also need to replace the receiver/drier do to the moisture that got into the system from that large of a leak.
Also just because you found one leak don't assume that is the only one. Check the system to be sure there are not
other leak points that will cause you a headache.
My 2012 was not quite as bad as your. I still had about 5 PSI left in mine when I put my manifold gauge set on it.
If you feel you can't handle this job then find an A/C professional to do it. One word of cation don't be tempted to
use that A/C stop leak. That stuff causes more harm than good.
Tools you should have to tackle this job are a vacuum pump, refrigerant scale and a manifold set to check the
pressures and for filling the system. You will also need to replace the PAG oil lost when you put the new parts in.
The job is not as simple as putting the parts in and squirting some refrigerant in. You should find a tag under the hood
that tells you the type and amount that the system holds.
Well I no longer need to worry about mine.
I sort of had an accident that took out the front end.
What really sucks is I just had picked up the parts to fix the issue.
