Timing advance after SPOUT recconect
Old Jun 16, 2021 | 05:57 PM
Mickw's Avatar
Mickw
I set my timing to 10BTDC, when reconnecting the SPOUT, i check it and its at 20, seems like it has a knock that wasnt there before. Do these models not have knock sensors? 1995 351w
Old Jun 16, 2021 | 06:13 PM
wwhite's Avatar
wwhite
Did you follow this procedure:
- have engine at full operating temperature
- turn engine off
- remove SPOUT only when engine is off
- run engine
- set timing to 10, tighten dist. nut, re-check timing is at 10
- turn off engine
- reconnect SPOUT
Nope, do not believe there is a knock sensor.
Is it pinging, like detonation, or knock like a rod knock?
Old Jun 16, 2021 | 06:17 PM
Mickw's Avatar
Mickw
More like a rod knock, and yes thats what i did.
reconnecting spout should send it to 19-20 though right
Old Jun 16, 2021 | 06:46 PM
My4Fordtrucks's Avatar
My4Fordtrucks
No knock sensor on a 351W. The computer will vary the timing at idle. I’m sure someone knows if 19-20° is normal or too much.
Old Jun 16, 2021 | 06:51 PM
Mickw's Avatar
Mickw
Im almost positive it is, but if anyone else knows, im definitely all ears. Also to be clear the knock is at idle, it goes away with speed unlike a rod knock. Maybe this was a pre existing problem and im just now noticing it.
Old Jun 16, 2021 | 07:26 PM
Conanski's Avatar
Conanski
Yes around 18-20 deg at idle is normal.
Old Jun 16, 2021 | 08:08 PM
kevinv10's Avatar
kevinv10
- turn engine off
- run engine
- turn off engine
- reconnect SPOUT
To add to this, make sure ALL electronic stuff is off. Radio, dome lights, lights, heater etc. Per my manual
Old Jun 17, 2021 | 06:34 AM
Mickw's Avatar
Mickw
may be my issue, i left the door open with the dome light on during the adjust
Old Jun 17, 2021 | 08:35 AM
Conanski's Avatar
Conanski
That won't matter, the idea is to not have a heavy electrical load on the engine but 1 little light bulb won't make any difference.
Old Jun 17, 2021 | 12:14 PM
My4Fordtrucks
I figured it was but have not looked at the timing with the spout plugged in, in a while.
Old Jun 19, 2021 | 06:24 AM
Mickw's Avatar
Mickw
started from scratch again, followed the directions to a T, knock is gone. That was weird haha
rbloodhound
Oct 14, 2007 09:09 PM
AZ 56 & 03
Feb 11, 2007 02:34 PM
FghtinIrshNvrDie
Oct 21, 2004 12:19 AM
pruefun660
30
Jan 13, 2004 11:45 PM
fordsrus
Aug 3, 2001 03:12 PM
