initial timing?
Old Jan 8, 2004 | 11:03 AM
pruefun660's Avatar
pruefun660
initial timing?
Hey I am tring to figure out what the initial timing is supposed to be on a 92 f-150 with a 351 and how to do it. can anyone help me out with this.
Old Jan 8, 2004 | 10:38 PM
Superdave's Avatar
Superdave
pruefun660
Are you meaning setting the base timing?
Old Jan 8, 2004 | 11:27 PM
andym's Avatar
andym
Somewhere between 8 and 10 degrees BTDC is good.
Old Jan 9, 2004 | 10:35 AM
EPNCSU2006's Avatar
EPNCSU2006
10 degrees is spec. It can probably safely go to 12 or so without detonation. Be sure to set it with the SPOUT disconnected.
Old Jan 9, 2004 | 12:03 PM
Superdave's Avatar
Superdave
I actually have edged my 95, 302 up to 15 degrees with the spout connector unplugged of course. It runs like a whole different truck. It has more power than at 10 degrees and is a little better on fuel.
I'm not saying its a race horse now, but it is better.
Old Jan 9, 2004 | 09:39 PM
924x2150's Avatar
924x2150
Hey guys, what and where is the spout connector?? I am clueless about that. I think my 4.9L emissions sticker says set at 10 Deg BTDC with in-line spout connector removed . There is a little symbol at the end of the instruction, does that symbol mean something?
Old Jan 9, 2004 | 11:20 PM
Superdave's Avatar
Superdave
Sorry, I can't help you on the 300 six. Someone here surely can though.
Old Jan 10, 2004 | 03:09 AM
MrDeath8666's Avatar
MrDeath8666
Ive heard about setting the timing...and some what watched my brother in law set in on my 302. We had to mess with the distributor to get the TFI off since i had to replace it, and screwed the timing up. He got it back close as he could (i didnt know you have to disconnect the spout). What all do you exactly have to do? Thanks...
Old Jan 10, 2004 | 02:40 PM
jakemarty90's Avatar
jakemarty90
the connector
I also need to know where the spout connector is on my 95 6I with m5sd
Old Jan 10, 2004 | 07:42 PM
bigric's Avatar
bigric
On the 92 and later trucks, the SPOUT connector is generally on the left inner fender, closer to the firewall. It is a small grey plug that goes into a two-wire connector. Just remove the grey plug when you're setting your timing and otherwise follow the underhood sticker for the procedure and timing setting.
Old Jan 10, 2004 | 08:23 PM
quaddriver's Avatar
quaddriver
this poster is correct, the plug is perhaps 3/4 inch by 3/8 inch and has red in the center, wire colors I think are green and green/yellow or yellow. All you are doing is pulling a bridge and disabling spark advance.
10* BTDC is where you want to be at around 900-1100 rpm (adj screw for idle on throttle body.
warning: if using MAF, dont advance it past spec.
Old Jan 11, 2004 | 12:21 AM
MrDeath8666
How do you disconnect the spout on a 91 since the TFI harness is on the distributor? Is it just one wire you have to pull out of the connector?
Old Jan 11, 2004 | 12:27 AM
quaddriver's Avatar
quaddriver
Ford puts the spout 1 of 2 places - near the dist held to the main TFI harness with tape, or near the master cylinder near the firewall.
all it is is a loop back for the spark timing signal - extra long wire that you pull the jumper out of.
Old Jan 11, 2004 | 01:04 AM
MrDeath8666
Thanks quad....also one more question lol. Ive never done timing before so...do you have to use a timing light? Im not familar with timing at all so sorry if its dumb question..only thing ive ever done was watch my brother in law set it last week, and we didnt know we had to disconnect the spout, and from what i saw, all it looked like was he was moving the distributor around i guess?
Old Jan 11, 2004 | 01:30 PM
Kasey's Avatar
Kasey
It took me and my brother forever to find the spout but we found it. The truck is an 87 and it was on the let side close to the firewall like these guys said.
