Timing Adjustment
Old Aug 3, 2001 | 11:21 AM
fordsrus's Avatar
fordsrus
Timing Adjustment
I had replace the pick-up coil and now I need to set the timing. But I don't know what degrees to set it at. The sticker on the truck says "Adjust timing mark to align with deep V notch on timing pointer" (10 degrees BTDC) So I set the timing to zero degrees and when i put the spout connector in it reads 10 degrees BTDC. I wanted to make sure I had it set right so I checked my friends truck, same year as mine and when you take out the spout connector it reads zero degrees. It's in the big V notch on the timing pionter. I was wondering if the deep V notch on the timing pointer is the 10 degrees BTDC or is that zero?
Ford 1989 F-150 4.9L
Old Aug 3, 2001 | 03:12 PM
sixbanger's Avatar
sixbanger
Timing Adjustment
rangerboy21
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Nov 23, 2004 12:06 AM
SShank42
Aug 18, 2004 03:27 PM
Boldt
19
Jan 8, 2003 11:51 AM
fordsrus
May 7, 2001 11:33 PM
fordsrus
Apr 27, 2001 12:10 AM
